2012 GMC Yukon Denali On 26" Rubbing Issue
DenaliDenis
I have 26" KMC Slides On My Truck. They are on 305/35 tires.
They rub when the wheel is about 1/4 turn. Does anyone have any tips on what to trim or use a mallet on?
Please help as this is annoying and don't want to have to make million point turns to turn around etc etc...
NathanJax
Vacation Nathan
Jax, Fl
You can heat the plastic up depending on where it's rubbing.
gryans07yukon
stockton, ca
With 28s I had to cut away some of the bracets at the bottom of fender wheel. . After cut dont make a sound or rub at all
D
DenaliDenis
Do you have any pictures of the brace you cut and how you cut it?
GalaxyBlackEsky
BlackedoutLT3
MD
Are you lowered or anything? I had 26" slides on my old Tahoe with it lowered and it rubbed a little. But if you are at stock height and rub I want to say it could be the offset on the rims.
gryans07yukon
stockton, ca
LoHoe
I use to have my 07 Tahoe lowered 2/4 on 28's. All I did was cut the plastic towards the bottom of the wheel wells and I had no more rubbing
NASTY GM
Nor Cal
I completely removed my plastic inners and I still rub on the firewall. Once my tires wear out I will switch over to a 295-30-26
ibarra503
