Heated/Cooled seats not working
BlackLTZ
I just noticed that my '10 LTZ Tahoe's heated driver seat is not working, the cooling either. the lights turn on but nothing happens. It was recently working. When I check the passenger it works on that one, you can hear a relay click on the passenger side but NOT the driver. Does anyone know
where I would be able to check connections or troubleshoot (besides obviously the harnesses under the seat)
thanks
GM Customer Service
Michigan
BlackLTZ,
I am sorry to hear that you are experiencing an issue with your vehicle. I understand that you are seeking advice from your fellow forum members and I might not be able to give you any technical advice. I am happy to look into this issue. Please private message me if I can be of any assistance.
Jennifer T.
GM Customer Care
ALL4WD
I'm having the same issue on the passenger side. Try pulling the circuit breaker that is under the dash and swapping it with the other side... see if your problem moves.
B
BlackLTZ
can you be more specific?
ALL4WD
Sorry, that wasn't very clear. If you look at the manual you'll see there is a fuse panel under the dash. There are circuit breakers (really just nice/big fuses) and there's one for each seat. Try swapping the driver and passenger breakers and see if your issue with the drivers seat is fixed but now have the problem with the passengers seat.
B
BlackLTZ
The drivers side dash im assuming you mean?
ALL4WD
On my Denali, yes but you need to check the manual for fuse box location and numbering.
twashi43
New York
What was the fix?
Sent from my iPhone using TapaCrap!
There was a connector at the rear of the passenger seat... one of the pins probably didn't seat properly and was bent. It was very hard to see at first. I shined a flash in there and found it. You probably already know that the ccm is located under the passengers seat. I would start there...
JML07denali
[emoji106]
BadDaddy2003
