20-22-24" GM Replica wheels
TriniHoe
Silver Spring, MD
I offer the 20-24" replica wheels. Any questions you have just post up I can dial it in for you.
http://www.tbssowners.com/store/index.php?act=viewCat&catId=17
How heavy is the replica 20/22 in comparison to the OEM 20/22. I have 20" Helo(s) with 305/50 tires on my Tahoe and when I remove a wheel, I have problems remounting the wheel because it is so heavy. I am thinking about switching to OEM 20 or 22 which probably is significantly lighter.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
the 20x8.5 weigh the same the 22s are 5 pounds more and the 24s are 13 pounds more then stock 20s
08grey
My oem 22's are way heavier than my oem 20's were
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
depends on what wheel. the texas truck is the lightest
08grey
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
a guy a mini truck mazda and i put the 22x9 Trailblazer ss wheels on with 255 30 22. that was a light set up.
08grey
Tony what do the replica 24's compare to the ones I have in 22
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
depends on the tire. a 295 30 24 is 38 pounds a 305 40 22 is 45 pounds.
if you have a 22x9 escalade with a 305 40 22 and then step up to a 295 30 24 in a 24 the 24s will prob be about 1-2 pounds heavier than the 22s.
if you went from the 22x9 with 305 40 22 and went to a 24x10 with 305-35 24 that tire is 44 pounds so prob 12-13 pounds more per wheel/tire combo. I can get a exact one next week just numbers of what I remember
TriniHoe
Silver Spring, MD
Thanks, in the spring I will switch to the lighter OEM 20(s) and lighter tires. According to Tire Rack the 305 tire is 45 lbs, not sure on rim weight but it is heavy, making the combo very hard to lift up.
Durobans
