Console Safe by Lock'er Down
RGNEWELL
Thanks Steve
I am glad you like the new model. They are selling fast. I just picked up the first batch and ordered more to be made today. I sold 6 just yesterday.
Thanks again for the purchase.
Everybody remember 10% using coupon code Tahoe.
StevenFromTexas
StevenFromTexas
Mr. Negative
Lubbock, TX
LD2011X pictures with a full-size 9mm pistol addition
On this forum, if there isn't a picture, it didn't happen, huh? So here are some pictures of the LD2011X Console Safe by Lock'er Down with a Sig Sauer P250 full-size 9mm pistol/holster installed, and lots of space for other stuff to fit inside. Of course, no weapon need be stored there to begin with, so billfolds, cameras, etc. can be safely kept out of sight when away from one's vehicle.
I don't want to get into a discussion in this topic about guns. The only reason I mentioned the Sig Sauer model is so that anyone who wants to check its dimensions will have a good idea of what can be installed on the left inside wall of the LD2011X if one wants to permanently mount a pistol/holster. A somewhat larger pistol will also fit. Most people don't lug around such large or larger pistols anyway. :)
One of the differences between the LD2011X and the LD2011A is that the LD2011A isn't big enough for a full-size pistol/holster installation on the left inside wall. The LD2011X makes much better use of the factory console space, so there's more useable room inside, which is another reason to select that model.
My comments on the five pictures below:
Picture 1: The completed installation and a picture from above. The unit is very easily installed. If you can use a screwdriver and a wrench, you're qualified to do a professional installation of the LD2011X. Heck, you can probably figure it out without even reading the short instruction sheet included, and the instruction sheet even has pictures for the reading challenged. :evillol:
Picture 2: One of my Sig Sauer full-size P250 pistols, and the one that will be housed in my 2010 Chevy Tahoe.
Picture 3: A washed-out flash picture with the flash showing some black marker "lines" to the upper left of the installed holster. Whoops, I forgot to remove the mess, uh, "lines" before I took the picture. :emotions122: Believe it or not, some of those "lines" helped me to position the holster perfectly before drilling two holes used to permanently mount the holster to the left inside wall of the LD2011X with two small screws/washers/nuts. :eek:
Picture 4: Another picture of the installed holster, which really is black, unlike that washed-out flash Picture 3.
Picture 5: A view from above before the pistol is inserted into the holster.
StevenFromTexas
StevenFromTexas
Mr. Negative
Lubbock, TX
My comments on the two pictures below:
Picture 1: The holstered pistol from above.
Picture 2: The holstered pistol from the side.
usmcss
What a beautiful addition to my 2013 Tahoe!!! It is perfect in every way!!!
Trying to figure out how to attach photos. Looks like I might have to put them up on Flickr first.
StevenFromTexas
StevenFromTexas
Mr. Negative
Lubbock, TX
You have good taste in accessories, usmcss! I can't think of a more practical, useful, and very moderately priced upgrade to make on our vehicles. :2cents:
n2advnture
I know this thread is a couple of months old but thought I'd throw this out there in case anyone might be interested in the future.
Just added the "Lock'er Down" - the LD2011X (not the E model - the X adds a TON more room after being installed)
Mobile Security Plus
I didn't bother installing the front and back panel and cross bar, it's secure enough with just the left, right and top panels bolted together and you gain a little more room.
After it was installed the safe, I bought some "industrial strength" velco and a Maxpedition holster. I put in the velcro on the back of the holster, inserted my CCW and then peeled the velcro backing.
I then, carefully lined up where I wanted the holster and pressed the whole setup so that the velcro adhesive was placed where I wanted.
Here's the Maxped holster that I used:
SNEAK™ Universal Holster Insert with mag Retention
The only thing that isn't perfect is that holster sits a little bit to far towards the driver side under the lip of the safe but it's not horrible.
My only knock on the safe is that there is no notch in the front edge to be able to use the 12v power that's located inside the console and run a cord out of the safe with being able to close the safe lid.
tojo152
PA
As long as you are comfortable with it that's all that matters. If it were me I'd epoxy a plastic or wooden block in between to give enough clearance when drawing the pistol. The last thing I'd want in a defensive force situation is for my weapon to get caught up on the console.
I think you should change your name to the candyman! Lots of sugar in that safe too. :D
n2advnture
That's a good idea, I'll give the epoxying a 6block a shot.
LOL @ candyman, those are my 6 year old son's "car treats" for when he's being good.
StevenFromTexas
StevenFromTexas
Mr. Negative
Lubbock, TX
tojo152 has a very good suggestion for you, n2advnture. Looking at your pictures, you might need to cut the block at a slight angle to get the bottom of the grip farther away from the wall so the entire weapon lines up better, and away, from the overhang of the lid.
As far as leaving the candy in the safe, and a youngster knowing the candy is there, I'd come up with a different hiding spot. I don't trust any kid to NOT get in trouble!
n2advnture
:waytogo:
Excellent point and I should have mentioned that the firearm is never stored in there without me in the driver's seat (unless entering an establishment where my permit prohibits it).
And it's never in center console with him in the vehicle.
Additionally, nobody knows the combo, not even the wifey.
Littleton, CO
Found this thread while looking to see if a Console Safe was available for a 2010 Tahoe. Wow! This met and exceeded my expectations. I ordered it on Sunday, received it on Thursday, and installed it on Saturday. With the video from Bobby Newell and the suggestions of n2advnture to leave out the front, back, and bottom plates, installation was fast. The ability to plug in the Ipod with the Safe closed is great.
I ordered the 2011X, but it looks like the 2011E would have met my needs. With the 10% discount from this forum, the cost difference was minimal. I can always add the other plates if I decide the extra security is what I need.
Thank you to RGNEWELL and StevenFromTexas for all of the instructions, reviews, and advice!
:cheers:
mikez71
StevenFromTexas
StevenFromTexas
Mr. Negative
Lubbock, TX
Rooster2000
