Locked radio
Brooklyn hoe
I recently purchased a oem radio but noticed it was locked after installing it, my question is there a way to unlock the radio with out going to the dealership.
GM Customer Service
Michigan
Hey there,
Yes, your fellow forum members are correct, without a code you will have to go to the dealership to unlock the radio. I would be more than happy to locate a dealership in your area and set up the appointment. Private message me if I can be of any assistance.
Regards,
Jennifer T.
GM Customer Care
Brooklyn hoe
Brooklyn hoe
Ok its been a while since I responded back to this thread, but I got the radio unlocked for 30 bucks with out going to the stealership the radio works fine even got free xm not sure for how long the only problem with the radio is the volume, it wont go down its stays on high does any one have any idea on what I can do to correct this.
08grey
Needs to have the radio programmed to work with your truck. Either you have the center channel or not but each has a different way it turns up the volume. Greg Cps av will fix it for you.
Brooklyn hoe
Brooklyn hoe
while searching for a way to unlock the radio i found a company that sells these machine to audio repair shops they actually gave me two people in my area that unlocks the radio i was shock when they gave me the price. The machine actually erases the vin number from the radios memory.
Danzigman
Galveston, TX
I am wondering if this machine is what is causing your issues, i thought the truck computer had to be updated as well.
Brooklyn hoe
Brooklyn hoe
I doubt it since the machine only erases the vin number from the radio.
BadDaddy2003
