Started the Lowering Process
GalaxyBlackEsky
BlackedoutLT3
MD
So I decided to install my rear springs today. Very easy install. I also left the 1" spacer as well as a 1/4"-1/5 stock bottom rubber mount. So probably isn't a full 3" drop yet. So once I do the fronts I will take out the spacer and rubber mount. Looks ok. Def takes away that huge stock gab. has a little bit of a cali lean on it. So I should hopefully be doing the fronts shortly. Any some pics of it
GalaxyBlackEsky
GalaxyBlackEsky
BlackedoutLT3
MD
Yeah I remember that. These are the same wheels I had on my 07 Tahoe.
Ben
PCB, FL
Very nice but you gotta take pics from a different angle from your sig toooo confusing lol
NathanJax
Vacation Nathan
Jax, Fl
What kind of lift are you putting on it?
:D
GalaxyBlackEsky
GalaxyBlackEsky
BlackedoutLT3
MD
Bwhaha. Shut it Nathan. Lol. I would love to go as low as you but def don't want to with the 26's. lowest I will go is 2/3-4. Hah
WHITEOUT
Dont Hate-Appreciate
Phoenix
Looks much better getting that rear down. TOTM got you moving huh...jk.
I'm with Ben, pics be blending. If I scroll fast enough up & down, I can put ur ride on air. HAHA
soulsea
Bar
Hey brent ... have you cut your brackets?
GalaxyBlackEsky
GalaxyBlackEsky
BlackedoutLT3
MD
I still have the bump stops in. So far feels fine. But I also still have the spacer in. I am going to see how the front sits after I install that. Plus I will see how the springs settle in the rear. I can tell you this kit is quality. The ride is night and day compared to the lowered Tahoe with groundforce springs in the back. But also I think the escalade air ride helps as well
I still have my bump stops in at 2/4 and mine rides well as well.
soulsea
Bar
Yup, I'm taking off my spacers tomorrow and I'm apprehensive that my ride will go from almost stock (at 36" in the back) to crap (at 35") ... from what Tony says 35.5 seems to be the threshold.
GalaxyBlackEsky
GalaxyBlackEsky
BlackedoutLT3
MD
Also can say this is defiantly a lot lower in the back then what my Tahoe was
NORCAL SS
SUV SUSPENSION GURU
what is the offset of your wheels like 15? look like they stick out a lot. Be careful ive had more than a few cutomers warp there 1/4 panels on 26s when truck came down and hit tire since offset stuck out way to much
---------- Post added at 08:02 PM ---------- Previous post was at 08:02 PM ----------
btw how low are you going in the front spindles?
GalaxyBlackEsky
GalaxyBlackEsky
BlackedoutLT3
MD
I can't remember off the top of my head the offset. They actually don't stick out in the back at all. Fronts stick out like 1/4 if that. Front going with the 2" drop beltech spindles I also had these rims on my 07 Tahoe with 2/3 kit
AdrienR
