Easy question - rear defrost button location?
glad2badad
I'm embarrassed to ask, but it's driving me bonkers ... where is the location of the rear window defrost switch/button on a 2005 Tahoe?
My only saving grace (maybe) is that I can use the excuse that this is my first Chevy vehicle (coming from a Ford Explorer). Liking the Tahoe much better. :happy3:
I've looked in the owner's manual ... Googled it, etc... no luck. In addition to pushing / prodding every button I can find. The 2005 is a LS model.
Thanks in advance for your help!
BirchyBoy
Are you sure it has rear defrost? Does it have the grid on the rear windows?
If your interior looks like this, it is below the defrost/panel/floorboard control:
G
glad2badad
Thanks BirchyBoy ... yes, I have a defrost grid on the back window, HOWEVER, that button below the output control you've illustrated / mentioned is blank (no icon) in my vehicle and it doesn't actually depress or anything when you try to push it.
Hmmmm..... now I'm second guessing myself and will have to triple-check the back window for the defroster wiring / grid. I'm 99.9999% certain it's there. I'll reply back once I get home and can look. Love my Tahoe, but not the gas mileage for my daily work commute. :)
Try to find the wiring diagram and look for shotty wiring...:hmmm2:
ScottyBoy
Shreveport, La
Its also possible that the previous owner replaced the AC panel with one from a truck with no defroster.
JochenWoern
Sacramento, CA
It seems odd to me that a 2005 Tahoe would have come with no defrost?
G
glad2badad
Yep - back window has the defroster, and Nope - no active button to turn it on. :shrug: So at one point something was swapped out it looks like. Bummer! Stinks not having a rear window defroster that works.
JochenWoern
Sacramento, CA
That does stink indeed.
I would imagine it not being too difficult to get that button and to wire it back up? The wires are most likely right behind the dash.
The local dealer should be able to check in their GM database if this vehicle was originally equipped with the rear defrost.
Again, it seems odd to me that a vehicle in 2005 would have been built without this feature.
YukonXL04
The Riverboat
Arlington, TX
Yeah my guess is someone replaced the AC control panel with a pickup version. You could always buy one with the button on eBay. I'm sure the button is soldered into the panel. Much easier to just swap the whole panel.
AdrienR
