I sell all HID kits
We dont have sealed beam HID kit, i'm sorry. They do make replacement kits for your truck where you can change the bulb. I just dont sell them.
ajs800
Michigan
What do you have for a 2007 Tahoe? I'm thinking either 4300k or 6000k...none of the pointless heavy blue hues.
Either one of those will put out a nice bright white light. I would recommend matching the fog lights too. Let me know if you want to place an order.
Coolade07
im interested in gettin a kit for my 07hoe. preferably 6000k.
so the $150+shipping deal is for the 12v only? and the 32v ballast would be?
my zip is 60016
my zip is 60016
32v ballest is $160 each. The $150/$160 prices are for your basic single beam 35w kits as in 9006, 9005, 880, h11 etc. Non bi-xenon and Bi-Xenon duel kits are extra and so is 55w kits. The 5202/h16 bulb is $189+sh.
The most expensive kit would be a 32v 55w Bi Xenon H13 or similar which is still only $249 with a life time warranty.
Shipping is $10 for ground for the continental 48 US States.
aiden2007
how much for my 1999 Denali, shipped to canada? I think I need 9006 for low beams?
If its not a sealed beam it is a 9006. It will be $150+shipping. I'll have to figure out shipping when I get back to the office. Im guessing shipping will be $20-$30 maybe cheaper, depends on the shipping company you want to use.
Fast55
Ventura County USA
I have a 2009 Tahoe and I'm interested in the low beams, but aren't the fog lights too small to take HID without melting? Do you have a matching bulb only for 6000K low beam kits?
I can do 6000k low beams. I dont understand your last question though, you only need 6000k bulbs for your low beams? You already have a kit? Our 5202 fog light HID kit is made for fog lights. The bulb itself is shorter then other HID bulbs because its made for the small fogs so no worries about it melting anything.
-Wes
Fast55
Ventura County USA
I thought the housing itself just couldn't take the heat, I didn't realize the bulb length was the problem for those that have melted the housings. Is there still a group buy or "package deal"? I'd like to do 6000K low beams, the fogs at 6000K, and just an upgraded bulb in the high beams.
We can do this. PM on the way
I've never had anyone tell me that their lens melted with my kit. HIDs burn at a cooler temp then halogens do also.
I'll check Monday for you.
Fast55
Ventura County USA
Wes, I finally got the kit installed yesterday, and it's nice and bright. However, I'm not too happy with the beam pattern. Is this a common complaint on the H11 kit? It has changed pretty noticeably compared to the stock bulbs. I don't see anyway to have screwed up the install, it's not like I've never done this before.
Rollin Thunder
Banned for Repeatedly Insulting Members
Va Beach Va
HIDs kits are like that. YOu just put a Xenon bulb in a halagon housing. But On my yukon the beam only changed a bit. But its common and really nothing you can do with out upgrading to full projectors.
titanium02
w7's or bust.
Norfolk, VA / ATL
What about projector headlights.. specificly.. mine. I believe HID's will work cause i've seen them put into other projector headlights.
You got 12,000K low beams and 12,000K fogs for me?
Rollin Thunder
Va Beach Va
THEY will make it better, but not awesome. To get awesome you gotta have real HID projectors and not halagon projectors.
What Rollin Thunder said is pretty much right. The HIDs are much brighter then your stock halagens were so you notice the glare alot more. The only real way to fix that is to do a projector retro fit which we do them here at my shop, but its not the cheapest thing.
Thanks for kinda explaining that!
Yes, your projector lights will be alot better then regular reflector based housings. As said below, it wont be the best but it will focus them alot better and thats what you want really. I sell alot of HID kits to Chrysler 300C owners and those cars have an option, HID projector or non HID projector and the non HID projector isn't that much worse then the HID projector, its a noticable difference but that bad at all.
For the set of 12k kits you want, I have everything in 10k, not 12k. I dont stock 12k to omuch because not alot of people want it. So its up you, I have 10k kits in stock or I would have to order the 12k kits.
Correct.
Fast55
Ventura County USA
Correct.
OK, but this isn't the first conversion kit I've used and I've never had one that changed the beam pattern this much. As long as the arc is in the same location as the filament in a regular bulb, the pattern should stay the same. I guess I'll go with PIAA's. Anyone want this kit cheap?
albac
