Vette66
Fresno, Ca
Installed new tail lights. OEM replacements were out of control. So I opted for a aftermarket LED style. Little more upto date look. My old ones had cracked and where dull. These are BRIGHT almost to bright for people behind me. Will see if I get pulled over for them.
Z-56 Hoe
What do I do????
Houston
They look really good.
Vette66
Fresno, Ca
I got the idea from the thread you had stated you didn't really like the ones you had. These are nice the 3 stage the blinker off-running light-brake light. There is no doubt I am stopping or turning from behind the truck.
Z-56 Hoe
What do I do????
Houston
Sweet. Those are the ones that will fit a barn door Tahoe too aren't they?
Vette66
Fresno, Ca
What's the transfer box?
Sorry not transfer box. It's a mixing box. It mixes the turn singles and the brakes.
Don't buy these yet. I have found a problem. I will work on it in the morning. I noticed after install it was getting some feed back to the 3rd light (slight glow of the LED's) didn't think it was an issue until tonight. Went fishing with the boys and found out the cruise control will not work with the running lights on. If I turn them off it works and also works with Day running lights. So it's feeding back to the cruise control as if the brakes where on. Not sure if it will take a resistor or a diode yet. Will do a how to on it when I figure it out.
Kman
Southern California
I just purchased a gas Honda pressure washer. 2700 psi at 2.3 gallons per minute. I absolutely LOVE it. I picked up the MTM Foam Lance and use Chemical Guys **** Suds II. Couldn't be happier. Here's a quick video of me using the setup (makes washing big cars a lot easier):
[yt]DU31_mtpiJs[/yt]
Tahoewhat
Ballin' on a Budget
TX
No they wont. The reverse light is in the wrong spot too low. You need this type http://www.amazon.com/Chevy-Tahoe-Smoke-Tail-Lights/dp/B0061J3KP6 Barn doors need the reverse light in the middle of the light basically, like this members
http://tahoeyukonforum.com/forum/showpost.php?p=685573&postcount=7
Just so you dont order wrong ones.
Keith,
that foam gun looks like washing the Tahoe wouldnt be so bad with that.
Tahoewhat
Ballin' on a Budget
TX
Yes they are the ones that will work.... http://www.tahoeyukonforum.com/forum/showthread.php?t=55088 Tahoewhat check it out
Dont apologize, you did not do anything.
Just wanted to make sure someone didnt buy the wrong ones. Edited mine to make more sense.
----------------------you edited same time i did--- lol
Stand corrected, but that would be modifying them to make them work, so technically do not fit. But the ones i linked to are plug and play no modifying. But i do like the ones you have better. lol. I would be modifying them. Mike on the other hand-- Not sure he would.
Vette66
Fresno, Ca
Saw that, was like oh damn he will figure it out. LOL
Waiting on the Wife to get home so I can work on the power bleeding issue for those lights. Will see.
Tahoewhat
Ballin' on a Budget
TX
I got it after i scrolled down. lol.
Was going to ask if you got the light figured out. Never heard of the power issue. Wierd.
Z-56 Hoe
What do I do????
Houston
Vette66 does your rear wiper move with you use your Hi beams or blinker not. Full pass just a jingle?
YukonXL04
The Riverboat
Arlington, TX
I have those lights on my barn door. You have to trim them as well as moving the little control box. But I don't have any cruise control or feedback issues... even after hacking mine up lol.
Hope you figure out what is causing it. I do t want problems with mine. But the 3 stage blinker is pretty sweet. And yes they are very bright at night. So far I love them.
ASG-MikeS
