Keyless entry (how to have oem working system)
saif najd
Hi,
Dear friends I have the 98 2dr tahoe and I don't have the keyless remotes and I want to have this feature.
Please tell me how can I check if I have the controller or not and how to add it if not
Thank you
saif najd
saif najd
Re: Keyless entry (how to have oem workibg system)
1SB OR 1SC your rpo code list. keyless was optional in the ls trim and included it the lt trim.
I should send you my vin number :thumbup:
By the way I just did a test (connecting the #4 with #8 on the OBDII blug and it worked :) :beer:
The lock unlock sound it came up, does that mean that all what I need now is the oem keyless remote?
Note: I have an after market keyless sys temporary but it is BAD the interior light stays ON! for some time thats why I wanted the OEM thing
(Side note) By the way I did the DRL disabling thing from the small board and it worked I will try to see if the local models wich comes without DRL have different board.
And I did the LED interior (white color) not 100% done but so far it looks coold and modern if I may say
SunlitComet
OBS Jedi-Do Good
unknown at this time.
there is an interior light module from factory that keeps light on for a little bit if you close the doors with the key out. and yes. remote number gm 16245105 for your vehicle.
saif najd
saif najd
Wow thank you :)
saif najd
saif najd
I asked my friend to bring me a number of parts but I found out he brought this to me do you think it is OK?
Can I program it?
_Dylan_
STAY FROSTY
Give it a try.
Connect #4 and #8 pins again. After the locks cycle then hold down the lock and unlock buttons on the remote and wait for the locks to cycle on the car. Once they do it has be programmed.
saif najd
saif najd
Give it a try.
Thank you I well try it and report soon
saif najd
saif najd
It is working, but I need to know what are the features?
For example when I programed the new remote I noticed the horn beeb can I chose the horn to beeb when I lock the doors by the remote?
Hodmjstone
