Blazed's 2011 Tahoe Build
Status
Not open for further replies.
Blazed
Blazed
Accepting Donations
Intake
---------- Post added at 03:23 PM ---------- Previous post was at 03:22 PM ----------
You have one don't you?
Can you send me a pic of yours installed?
felixgun
Lafayette, LA
**** airaid jr. This dumb ass thing has come off like 5 times total and 2 in the last two days and its giving me a reduced engine power message.
It's coming off.
Damn that sucks man. What are you going to replace it with?
Blazed
Blazed
Accepting Donations
I don't know I don't have any money in the "replace things I've already bought" fund right now so probably just stock.
But this is why the stock intake has that flex section.
---------- Post added at 03:41 PM ---------- Previous post was at 03:39 PM ----------
This is what it looks like at the intake box when the throttle body portion is properly seated.
WHY
felixgun
Lafayette, LA
Ah I see. I bought the full airaid cai that had the fine filter with the heat shield so I never had that issue. You could always get the matching cone performance filter and heat shield too and you'd be able to leave the intake tube on.
http://bit.ly/175KckG
Blazed
Blazed
Accepting Donations
I emailed airaid while I was talking to y'all earlier and they have already emailed me back and suggested I clean the tube with brake cleaner to make it less slippery and that the screws only need to be snugged plus a 1/4 turn.
Blazed
Blazed
Accepting Donations
Thanks lee. That's exactly how mine looks.
Goodinblack
I Like Tacos
Dirty South
You welcome bro.......
Just tighten them real good..... but don't crack anything.
When you tighten it all..... try pulling on the tube to see if it comes loose........ if it does..... loosen it and put it back on and retighten it.
Blazed
Blazed
Accepting Donations
It's just so stupid how difficult it is to change the intake tube and make it work should be easy.
Like it was for you guys.
Blazed
Blazed
Accepting Donations
Airaid jr. fell off again today.
I already emailed them lets see what they say this time.
At this point I'd just ditch it out of frustration. I have a very low tolerance for that stuff :)
NORCAL SS
SUV SUSPENSION GURU
volant no prob ever on any 5.3/6.2 07 up truck ive worked on.
Blazed
Blazed
Accepting Donations
I dont understand why I'm the only one having issues with this...
I mean you guys saw the picture of the line up of the air box to tube it clearly isnt my fault. Either I got the wrong part by mistake or my truck is seriously different from all the others.
08grey
Had this problem on a older Sierra. We used the acordian style tubing connection from the factory intake to make the connection more flexible.
Blazed
Blazed
Accepting Donations
Ill try that thanks.
---------- Post added at 04:47 PM ---------- Previous post was at 04:39 PM ----------
Btw lee. I found the squeak...
It was the front bumper.......
I fixed it.
---------- Post added at 05:08 PM ---------- Previous post was at 04:47 PM ----------
That thing isn't coming off.
Ill have to try something else.
MACHO
Seattle, WA
Blazed, when the grommet is seated on the throttle body, can you pull the Intake tube towards you (towards the front of the Tahoe)? That may line it up better. I noticed I had to leave the hose clamps semi loose and play with how far/not far I inserted the tube into each grommet on the intake side and throttle body side. Then I torqued all the clamps down fully.
Status
Drewphil
