Airlift Helper Bag Part Numbers for Lowering Springs
NORCAL SS
SUV SUSPENSION GURU
Pm me for info i offer all the helper bags for lowering springs
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
What about for pedders coils?
Should be the same been a while since I did helper bags in those but I put up pics of a truck I did last week the pedders coils next to 5305 pretty much same ID.
Blazed
Accepting Donations
But while compressed they are different heights. Because the 5305 gives 4-5 inches of drop and pedders barely barely give 3-3.5
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
overall height is fine. if you measure your pedders coils you will see upper coils are touching also. if you look how much space is on bottom you will see a 6 inch bag will take up all lower coils and fill up the spring area also where at a 8 or 9 inch bag is to tall. You want the bag to take up as much as the free coils (not the dead coils) as you can because they wedge themselves between them when you air it up. With a full 3-4 inch drop the 8 inch bags will rub on the upper and lower mount a lot when suspension compresses which could lead to a bag rubbing and failure. If you have space in there gives the bag a little place to move. Airlift does include rubber pads for top and bottom on their kits i just rather have a little wiggle room to be safe.
I think with my 3.5 drop in back of my escalade its like 7.5-8 inches from bottom to top inner spring mounts forgot what it was exactly
Blazed
Accepting Donations
So you think a taller spring needs a shorter bag?
I posted pictures of the compressed pedders coils and they have to be taller than the bell tech coils compressed because with no spacer you get a 4-5 in drop and pedders is less than 4 inches at all times. If the bell tech coils need a 6 bag pedders would need like a 6.5 or 7.
Unless I'm completely missing something.
I did not see your post after you changed it until I posted the above but still I think it may need more than 6
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
get the truck on level ground.
check to see how many free coils you have and measure how many inches from first free coil to where the springs start to touch eachother
Then you can order the bag kit accordingly. If you think you can fit 8 inches in there and from first free coil to where the coils start touching is 8 inches then go for it.
There is no 7 inch bag which I wish they would make you have either the 6 inch option or the 8 or 9 inch option
Goodinblack
I Like Tacos
Dirty South
To anyone wanting a 2 inch drop....actual spring..... WITHOUT spacers.....
I run Tony's springs with Airlift 60742, no issues.
bub
jersey
is the top part number for the djm 4" tb coils?
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
djm only made 4" coils for the 07 up trucks is that what your talking about?
bub
jersey
my tahoe is an '01. i bought them from you about 2 or 3 years ago. it was part of a kit you sold. all i know is they are djm tb coils and they came with the rear hardware kit and djm shocks.
SC88
Chicago Burbs
I'm running 60472 on my Suburban and just noticed last week that I have to put 50lbs in the bags just to level the back to the front.
I have the 2/4 lowering kit with belltech shocks anyone else have to run a lot of air in there bags? I know the instructions say 35psi max but is anyone going higher? I do not want to blow these.
Goodinblack
I Like Tacos
Dirty South
Hahahahahaha 50?
I have a 2 inch rear drop on a Suburban
Airlift 1000s 60742s.
I have NEVER run 50 psi. I ran 40 and blew the right side.
Now I never run more than 30.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
sam good talking to you on texts just hit me back there.
bub
jersey
I found out I have the djm 5.5" trailblazer springs. Still run the 60742 bags in those? I think they are close to the 5305s if I remember correctly.
Phlipnstik
