Blazed's 2011 Tahoe Build
Status
Not open for further replies.
Blazed
Blazed
Accepting Donations
And I'll check and see if I have pictures later too
Blazed
Blazed
Accepting Donations
Got my AVG MPG from 11.7 all the way up to 15.3 since my tune.
Blazed
Blazed
Accepting Donations
Tony is sending new ones but I think I'm gonna fab up custom ones.
NORCAL SS
SUV SUSPENSION GURU
Update on the DJM situation?
Im trying to find pics how was installed how he had on it on. Mine been on over a year and going on strong... even with towing and didnt hit like his has so trying to see what caused it.
Blazed
Blazed
Accepting Donations
Can you post a picture of how yours is please?
NORCAL SS
SUV SUSPENSION GURU
I rented the track at bowing green for my national truck drag strip event and ill be back on monday. Ill take pics and clears the bracket. maybe bracket from gm was off I dont know but ive never had one break that was installed correctly.
Blazed
Blazed
Accepting Donations
Ill just have to wait and see for the meatime ill use the stock ones
NORCAL SS
SUV SUSPENSION GURU
Do you remember how you had the bar set up. Inside or outside of the brackets??? if its on the inside of the pass side it will rub the frame like you showed and break the link.
here is my drivers side from the pic I found on the net when i just hand tightened it up with the zerks.
Blazed
Blazed
Accepting Donations
Yep thats how i had it
NORCAL SS
SUV SUSPENSION GURU
yah mine clears and so do the others ive done. For some reason your panhard bracket sticks out a little more and rubs. Either way new one is coming your way.
NORCAL SS
SUV SUSPENSION GURU
yah i get pretty good mileage on the 6.2 especailly after the ported manifold/cat taken off/intake/crank pulley
Blazed
Blazed
Accepting Donations
What gains do you see from ported manifold.
MACHO
Seattle, WA
You guys have 5.3s with the 6l80e right. 3.42 gears
Yes as Blazed said. I was actually the rare case that lost MPG's with the tune bc my driving style: throttle input is very efficient. Higher shift points caused the loss. However the improvement drivability was worth the sacrifice.
Blazed
Blazed
Accepting Donations
So you never got that worked out? Just learned to live with it?
MACHO
Seattle, WA
Exactly. With primarily highway driving the tune can really rack up some high MPG's 18-20. I had another tune sent to me that was 50/50 between the original modded tune and the stock tune. Been averaging 15.5 compared with 14 on the 1st tune.. I'm hoping to get more with the summer gas. If I was driving with the stock tune, I'd prob be around 16.5+.
---------- Post added at 03:01 PM ---------- Previous post was at 02:59 PM ----------
As an aggressive driver, I wager you're going to see some really nice gains!
Blazed
Blazed
Accepting Donations
I wonder if Texas ever switched to winter gas
Status
Drewphil
