5/6 Drop on 01 Yukon...installed and HAPPY.
NORCAL SS
SUV SUSPENSION GURU
id have to see a sdie pic.
Here is my 3/5 kit (my rear spring with 1 inch spacer in)
Screwd up 6
Looks good. I would have expected a 5/6 to be slammed. Have you taken actual measurements to see if you actually gained those numbers?
M Hankel
Vancouver, WA
On a 305 40 22 it should be around 32-32.25.
Is that measurement with or without the flares though? From what I've seen, the flares account for about 3/8-1/2" when measuring from the ground to the lip. The trucks with flares will also "appear" lower because the gap from tire to lip is smaller given the exact same drop values.
Mike
NORCAL SS
SUV SUSPENSION GURU
just had a guy call me in rear he just put my springs in and only dropped back 4 inches. I told him the springs are supposed to fit outside the spring cup on the top of the frame and it wasn't sitting right and sure enough he checked and top part of springs werent sitting in right and put them in and all is good now.
Just something to check whenever you guys do springs on the back of these trucks
HeavyHoe03
