brake problem
bsbladine
Hey, I'm new here but completely out of ideas on this problem. I have a 99 tahoe 4 wheel with brake problems. When I hit the brakes they shake like mad but it is only after a long drive or when I am at high speeds or towing my boat. I can run around town with little or no problems. I have replaced the pads and rotors and that did nothing. Any other ideas?
ravingmadman
Chief Knuckle Buster
Greater Seattle
Drums/rotors? Wheel bearings? Ball joints? Could even be steering. Describe the shaking- is it side to side, or wheel hop, or studdering?
B
bsbladine
It is a side to side shake. The ball joints were just replaced about 20,000 miles ago and the wheel bearings seem to be ok.
B
bsbladine
Shocks seem fine also. Afriend thought maybe it was a leak in the vacuum hose to the master?
ravingmadman
Greater Seattle
Can you feel the shake in the pedal, the wheel, or neither? I'm still getting some background. I'll spit out a prognosis in a minute.... :)
ravingmadman
Greater Seattle
Ok. I bet you'll find a good amount of play in your pitman arm, and idler arm. Jack one front wheel off the ground, push/pull left and right on the jacked up wheel. It shouldn't move. Push/pull top to bottom, it shouldn't move. Left-right movement is pitman arm/idler arm, top-bottom is wheel bearings, since you've done the ball joints. If you aren't feeling anything in the pedal, you've replaced the pads/shoes- I'm skeptical of the brakes being the culprit. There are many other forces exerted on the rig while decelerating, and a wobble like that after replacing the brakes smells like steering or suspension to me. Give it a go- I might be way off, but that would be my next thing to check. I have a write up on how to swap out your pitman arm. It isn't expensive (~$50?) or difficult.
B
bsbladine
So if I find side to side movement when I jack up the wheel, I should replacement the pitman arm and idler? Or just the pitman?
ravingmadman
Greater Seattle
You'll want to do both, because if one is worn, the other is probably just as bad. The pitman arm is like $50, and the idler arm is something like $30. it will take you an hour or two to do.
Here's a guide for the pitman arm- the idler arm is super easy.
http://www.tahoeyukonforum.com/forum/showthread.php?t=2052&highlight=pitman+arm
ravingmadman
Greater Seattle
Welcome to the group!!! I have the most boring job in the whole world, so to not just gossip on facebook, I hang out here. There are many really, really smart folks here, who've had the same problems you'll have, or have had, and know the easiest way to fix it. Keep us posted, and get some pictures up of your ride. :drunk:
B
bsbladine
Ok, after a long night I got it back together but I am not sure I got the pitman arm back on the steering gear box completely. Is it ok to have some of the spline still showing or do I need to pull it back apart and get it on farther?
ravingmadman
Greater Seattle
Yes, you'll have some spline still showing. It is a compression fit, so just make sure you get the proper amount of "oompf" on the nut, and you're good to go.
B
bsbladine
Great, thanks for all the help. It seems to be the answer to my shaking problem. I really appreciate the advise.
B
bsbladine
Well, now after replacing the idler and pitman arms, I have a pulsing going through the pedal instead of the wheel shake that I had. Any more ideas?
Thanks
ravingmadman
Greater Seattle
Only when you hit the brakes, or all the time? In your original posts, you mentioned you've already replaced the rotors and ball joints, right?
ZaZaZazzels
