The deal with e85 is this.
it is
a: corrosive to seals and some metals
b: has les energy per gallon,
c: and stoich is a differnt ratio, so you need either longer pulses or larger injectors to achieve the same combustion ratio
D: the higher cotane means it burns more slowly and coolly, so you can run leaner OVERALL mix or more timing with e85 or higher compression (or all the above) than you cna with gas.
e: IIRc ethanol actually ignites about as easily as petrol and atomizes about as easily so you don't need some monster spark system
What would be a piston melting tune on 93 octane gasoline, and a ragged edge tune on 100 octane unleaded, is very safe on e85. Thus unless you have a flex fuel vehicle, if you tune for e85 and then have to fill up with gas, you are going to run like poo... Way way fat, and probably knock from excessive timing too.
IIRC e85 was about the 42% less energy, stioch was around 9.7:1
You would think you needed to throw 42% more fuel to make up for it, but you don't. What folks did was run ~25% more injector so you get a leaner final mix under open loop, and let the ecu find stoich with it's adaptation. Then bump the timing up 3-5 degrees.
At least that is how you do it on OBDI vehicles that my friends have converted in other places to run on it.
Problem is again that when you are NOT using e85 *** it isn't flex fuel, the timing and fueling are way off, and you get poor power and economy. you need to reflash it back.
