2007 Tahoe Build with Audio
A
Andrew2944r
So got the new tailpipe and Magnaflow installed. Also just finished up replacing the stock Airshocks with some Arnott Air socks for those with air shocks
https://www.arnottindustries.com/
Very easy install and only took me about 2 hours with a floor jack.
Added the Airlift bags for an extra helping hand with the weight.
And now that the airshocks are actually holding air the rear actually came up quite a bit.
Blazed
Accepting Donations
I personally like it better at that height!
A
Andrew2944r
looking good man. If your interested check this out will bring the swaybar parallel again with ground
http://www.tbssowners.com/store/index.php?act=viewProd&productId=201
ALSO MAKE SUREEEE to flip the upper bolts the opposite way. many times the threads come and cut the tire. Flip it the other way so head faces tire
What is the advantages of upgrading and would I even tell the difference as the swaybar is not facing down severely.
Yea I was looking at it but there is no way the thread on mine could cut the tire, has plenty of space.
NORCAL SS
SUV SUSPENSION GURU
no prob just making sure on the bolts always safe then sorry.
If you bring the rear to where it was before I would look at getting them seems like rear is much higher now or maybe im seeing it wrong?
A
Andrew2944r
It is higher now. The Tahoe has working rear shocks again, lol
NORCAL SS
SUV SUSPENSION GURU
hey sidenote brake/rotor painting
Get some semi gloss black and first brake clean the rotor and calipers and then paint it semi gloss black. You can get some on the face dont worry pad cleans it off and doesnt affect the pad at all.
I just did my f150 last week rotors i put in back of 2004 and repainted it with rustoleum semi gloss black and just makes it look a lot cleaner back there
AND REAR
[/IMG]
NORCAL SS
SUV SUSPENSION GURU
I like your 150 Tony.
Sent from my GT-N8013 using Tapatalk 2
thanks man. Been in the family since 1998 and I lowered the day it was bought new. Been a great truck just someone hit the rollpan so getting it repainted.
NORCAL SS
SUV SUSPENSION GURU
dam looks nice.
question how much do you think all the sound equipment with batteries will add to the truck like 900-1000 pounds?
Drewphil
