What did you do to your OBS in 2012
clownracer
busy year for my yukon
k/n airfilter
spark plug wires
plugs
coil
waterpump
low temp thermostat
fuel filter
front hubs
wheel bearings
2500 calipers
pads
rotors
fuel filter
4x4 actuator
transfer case switch
starter
ignition switch
fuel pressure regulator
rims
tires
hopefully 2013 will bring
nv4500(next weekend)
cummins swap(summer)
SAS (fall)
retorq
Kingman AZ
Transmission #2 was the big one here just recently. Also I believe I ran a 15.99 in 2012, if not it was just before ... not too shabby for a 4 door stock 95 TBI turd. Hahahaha
I def did the 2500 master and front caliper swap this year ... swapped to steel braided lines too at that same time.
_Dylan_
STAY FROSTY
finally found a cupholder for my center console :D
Gzes
the drifting 2dr
Wichita tx
Gotta fix my cluster issue... Then im doing led dash lights and am gonna get led tail and tail light guards
inthechateau
Maryland
2012 was a bad year for my 96. Blew rear differential on way to MO from MD. Half way accross Ohio seal went and left me stranded on side of I-70. Limped it to small shop at next exit and they helped me out with new seal and crush sleeve. Had dinner with owner of the shop that night and started the next morning on the rest of the trip. 2 O2 sensors went up on that trip also as well as a fuel pump on the way back a week later. Body is loosing its fight with rust real fast. Hope it holds together long enough to get my 99 project Hoe on the road.
The 99 once on the road, witll get 2" body lift, 2" suspension lift, dual batteries set up, front hitch and winch, Air ride for rear diff to handle 26' Chateau camper trailer, Volant COI, 3" Magnaflow exhaust, and may even look into a little bit of power chip for ECM.
AZ Tahoe
Arizona
Well on Sept 14th 2012 I purchased my 99 2DR for 4K. Going through the paperwork I found in the hoe I discovered it has a new motor and trans with only 30 miles on them.
Then began to replace parts -
HVAC Plenum under dash - replaced with new
Rear 4x10 Kickers
Fronts 5.5 Kickers
Rear Dif Fluid change and painted cover
New alternator
Blue LED Cluster
Replaced rear bakes and equip
New acuator
Spider injection
CREE LED bulbs under dash
LED in rest of interior
For 2013 I have planned
Corvette Servo - Ordered today
Belt tensioner - ordered today
6" Lift
35 x 12.5 tires
Long tube headers
Dual pipes out the rear
New seats in front
Redo rear seats to match fronts
Subs built into rear
Small tool box built into rear
2" Crowl hood
Hindden front winch
CAI
High Flow MAF
Front grill swap (I have work truck style)
Hids
Make a roof rack
KC lights
replace steering box
And on and on and on :)
2012 - was a slow year for my Escahoe, but I did do: Tires, Reverse Camera, Waterpump, Heater hoses, A/C Compressor, and Red LED Lights through the whole interior.
The begining of 2013 has started rough, with my Timing Chain, slipping time so I'm not up and running yet but should have it on the road tomorrow. However I do plan on finally replacing my front differential (went out, so I just pulled it off the truck), and getting some XD Misfit wheels, and new tires, and whatever else comes up. :gr_grin:
Donnie Yukonie
Yates Caretaker
Mine was a good year, This year will be a little slower
6.5 inch lift installed currently at 4.5 until I add the bigger block and crank
18 inch KMC Revolver rims
35 inch Nitto Mud Grapplers
Plastidipped the whole truck
Drilled and slotted Rotors
Rebuilt my front end
Snorkel
NBS center console
denali read door panels
Tow mirrors
raptorforme93
Tampa, Fl
2012 was kinda ******. Got my Hoe broken into and $1600 worth of stereo stolen, burned out my tranny, and AC evaporator took a shit on me, also the 4x4 actuator went out. 2013 has been pretty good fixing all of those though!! Hopefully getting some new shoes for it soon
GMCYukonDriver
CA
New wheels and tires.
Passed smog with a catalytic converter that's been rattling for over a year.
Bolted on a whipple supercharger.
Got in an accident, fought with insurance, avoided salvaged title. Now it's getting fixed, but with different lights and a painted diesel bumper for fog lights.
Phone Man
Long Island NY
New transfer case, u-joints, front end, tires, Amsoil fluids in diffs, alum dizzy, Taylor wires, 4 headlight mod, driving lights.
VicYukon
Stockton, ca
Well me, I had to rebuild the engine of my Kon witch took some of my funds to get painted. Then replaced ball joints. Hopefully 2013 is better to me
HOEIN
Rhode Island
my 1999 tahoe in short
Well I bought my basically stock 1999 tahoe back in December 2011 from a friend of the family for $5000 with $97k on it and a lot of work done to it from the previous owner mechanically. I cleaned it up and painted the stock wheels and here is how she sat Jan 2012
I did some work over the spring/summer
- New ac lines, compressor, dryer, orifice tube and refridgerant
- New front calipers, pads, new rear drums, shoes and springs, bled all brakes (they still sucked)
- New plugs, wires, cap rotor
- New radiator
- New 4wd pushbutton
- New fuel pump and locking ring
- New oxygen sensors
- New Magnaflow catalytics converters
- New knock sensor
- New Thermostat
- New belt and tensioner
- New battery
- New Starter
- New work truck grill with tinted headlights and turn signals
- Used rock guard
- New windshield
- Used 72 watt each LED offroad lights ($125 bucks a steal)
- Used Outlaw II 15" wheels with 33" BFG ATs 12.5 ($300 bucks another steal)
- New shocks, rear shocks have coil springs to fix rear sag
- Added 2" blocks in the rear and a torsion bar crank in the front
- Basic tune using hp tuners ( still in progress, once I get new front o2s put in I will be dialing it in more)
I then go ambitious and added a 3" body lift from summit and some flexy flares and a nice diamond deck filler plate on the back
I then got a little over zelous and get stuck while hunting one day what I thought was solid ground was frozen marsh, I learned the downfalls of the open differential very quickly.....
Around the same time I almost rear ended someone that stopped short in front of me because the brakes suck on these trucks, I did some research and ended up with
- new hydroboost power steering pump
- new hydroboost power steering lines
- new hydroboost unit
- new master cylinder from 1 ton
- ebay hydroboost adapter plate for astro van
I also decided the open diff had to go. I upgraded it with:
- new detriot true trac differential
- new outer wheel bearings and seals
- new carrier bearings
- new fluid
- summit racing pinion bearing support diff cover
and here she sits after it all! Oh yeah I forgot to mention, I did everything myself, built not bought baby :boti:
VicYukon
Stockton, ca
Nice job HOEIN, I did all the work on my truck myself also. It always feels good and pride when people ask about the truck. NICE HOE
HOEIN
Rhode Island
Snorkel
NBS center console
Tow mirrors
Hey donyukon what kind of snorkel is that? any info on how you did it would be great, I would like to do one on my hoe.
Ken
Hodmjstone
