What does your volt meter say?
sumo
dn ʇǝƃ ʇuɐɔ & llǝɟ ı
rhode island
Just comparing to others. What ate you guys running at? I'm showing 14.5-15 volts at idle. Wonder if my battery is really bad or if I got a charging problem.
stevek
Dallas, TX
The alternator is just active and charging. When it's at a proper voltage it'll kick off and that's when you'll see it around the 12v mark
sumo
sumo
rhode island
thats the thing though. Its always there. I need to do a battery test. Its seems to be going on 5 years on oem battery. Some days are fine and once in a while it seems be be slow start.
StevenFromTexas
Mr. Negative
Lubbock, TX
sumo, your picture looks just like the display on my Tahoe. The meter rarely (almost never) makes it back to straight up. It's almost always to the right of center. Just like me. :Big Laugh:
Ryan1126
thats where it should be, i dont see a problem?
stevek
Dallas, TX
My battery died after 4 years last week... replaced with an Optima 34/78 and the starts don't seem as sluggish anymore. I don't know why it's not listed as fitting, because it fit perfectly in the factory spot and the brace fit as well.
sumo
sumo
rhode island
Oh ya, defiantly time to replace. Dead battery this morning.
sumo
sumo
rhode island
Im surprised that i got this much out of a oem battery
doubletapdrew
They should be at 14.5v while running and around 12.5v when off.
When the factory battery in my 07 went toes up (think it was around 4 years old at the time) I replaced it with a 78dt6yr which is what we usually put in the duramax pickups. Our tech said the stock battery is awfully puny for all the electronics the denalis have so they don't last very long. I think my factory battery tested out to something like 35 amps on the load test, lol. Def. time for a replacement.
imi4tth3w
no. no. wrong. no. absolutely not.
when you car is on (engine on) it should ALWAYS be around 14-15v. only time it should go down is because of either lights, stereo, any electronic drain. if it goes down to 12, 13v under normal driving, something is wrong with your alternator.
there is only a few exceptions to that, as in my honda civic VX which has ELD (electronic load detector) that will disable my alternator for a little bit when there is no load being put on it and driving under 40 mph to save fuel. this savings is extremely minimal but this only apples to certain honda fuel saving vehicles. its every little bit that counts. which does not apply to any full size chevy. but otherwise, see above paragraph.
Modded
That Guy
That is not true for the case of these NBS or NNBS GM cars.
They have regulated voltages and most of the time the voltage is under 13 volts unless there are a good amount of items in use (like the A/C or headlights). GM said it is done to save gas but I think it is the loads that cause it.
I know this because I have a system and Stinger volt meter installed and when the voltage goes down while driving I can switch on the headlights and it will go back up a bit.
stevek
Dallas, TX
:hmmm2:
If you were a little bit more educated, you would know that's not true with these trucks. PS - No need to call me out like that thinking I'm an idiot... it worked against you that time
Yep^
Vegasf6
Las Vegas
If you are seeing 14.5 to 15V your battery is excessively low. I think you have discovered this already though, huh? It either suggests a weak battery or some sort of parasitic drain in your system.
Also this constant charging at high currents (as that is WHY the charging voltage is so high) is tough on your alternator.
