Wiring doors
matt14
san leandro,ca
How are you guys wiring the doors with new speaker wire? If i remember, there is a connecter in the door jam, so are you guys drilling holes in the connecter and running the wire through that? Still dont have the funds yet for some door speakers. Just tryin to figure out for when i do. Pics are appreciated to.
thehoe92
fo sho
The916
its a very large grommet that you can fit wire through and I think it comes in behind the kick panel but I haven't tried it yet.
good luck :)
OmarR
Indianapolis, IN
Basically, yes.
I didn't do speakers, but I did window modules in each door. I had to run 4 wires into each door, and that's what I did.
It's just time consuming and a little PITA.
sdgd711
Atlanta, Georgia
I thought it was only the rear doors that have molex plugs on them. The front doors have a plastic piece that clips to the body of the truck, but you can still run wires through it without drilling.
OKLAGMCRUISER
Need drop...send $
Kiefer, OK
i undid...that is a word...seriously...the plugs and ran the wire thru the plugs/holes in doors and kick panels...takes like 3 minutes each side.
tast101
Colton, CA
Here's what I used to run the wires from my crossovers to my doors, http://cgi.ebay.com/SOUND-QUEST-HOM...1e58250df7&_trksid=p3286.c0.m14#ht_2996wt_996 , but I hate the company hifisoundconnection, got my wire on time but took a month to send my speakers, even after I told them to cancel the order after I called on the 3rd week. They never cancelled, credit my card and then sent the order. So if you could find it from a diff seller, great.
denalianyone
NYBlackLade08
New York
it's a pita and time consuming. I put a small hole in the front and rears to feed wires
DarkTahoe00
IN
I ran mine through the rubber grommets using a coat hanger with the wire taped to it and feed it through! It took a little time but not long at all!
OmarR
Indianapolis, IN
You are correct. I should have been more specific.
rossida
