JLMoses
My 1994 Blazer does not have the second battery tray....any idea to how bad it would be relocating the things that are in the way to install the tray? any help i would be grateful...thanks
go to the junkyard and find a 96 to 99 and get the batt tray out
you will need to move the canister to the side and get that bracket
too. i made my bracket fot the tray then i found out the 96 to
99 had this set up i even got the windshield bottle thats under
the tray so i took the top mounted washer bottle off and use that
space for the alarm siren and relays.
also get a stinger pac-200 relay to put between the two batteries so they won't discharge each other. don't use a battery isolator.
i put the pics in the wrong thread . they are under THOUGHTS
ON POWER in this audio & electronics.
