Plastidip Grill
steven johnson
wisconsin
how many cans of plastic dip did you used on your Suburban ? i have a slverado i going to try it on. Any information will be helpful . thanks
Goodinblack
I Like Tacos
Dirty South
2 If I remember correctly.
I would buy three just to have it, then return the last one if you don't use it.
Keep in mind you have to do about 3-4 coats.
Y
yooks11
Just picked up 4 cans today - might go plastidip crazy if I get time! I'll do my best to take pics along the way.
steven johnson
wisconsin
so to all the plastic dippers - in sounds good, But if i don't like it does it just peel off or buy a new grill ??? thanks
purple 'hoe
Green Bay, Wisconsin
Plasti-Dip can peel off
I sprayed my grill inserts, not my whole assembly. Never took it off. Never have had a issue since. Only did a light coat however. Just enough to make it look darker I just masked off what I wanted dipped and what I did not want done.
Used it on my front bumper cap and valance. Gonna have them redone correctly though. Looks terrible IMO. Plasti-Dip is nice for somethings, but not everything.
Y
yooks11
So instead of using the PD for my grill, I ended up putting some coats on the new wheels I just got. Put four coats on but didn't let them dry for long enough so one wheel peeled as I was loading it into my vehicle. Going to redo this wheel and add 2 more coats to each of the others.
Once all this is done, I'll be PD'ing my grill.
AZSCTACO
Phoenix, AZ
Here is mine......
MACHO
Seattle, WA
If the peeling isn't too bad looks like you can rub paint thiner on the spot and then respray:
https://www.dipyourcar.com/pages.php?pageid=37
Y
yooks11
Initially, the peel wasn't too bad but I panicked and made it a bit worse. I then started peeling the entire wheel but it was hard to get certain areas. Did my best and then re-coated it six times. I should have some pics tomorrow.
tonaaayyyy
Can't wait to see it
JeffK
