Plastidip Grill
steven johnson
wisconsin
how many cans of plastic dip did you used on your Suburban ? i have a slverado i going to try it on. Any information will be helpful . thanks
Goodinblack
I Like Tacos
Dirty South
2 If I remember correctly.
I would buy three just to have it, then return the last one if you don't use it.
Keep in mind you have to do about 3-4 coats.
Y
yooks11
Just picked up 4 cans today - might go plastidip crazy if I get time! I'll do my best to take pics along the way.
steven johnson
wisconsin
so to all the plastic dippers - in sounds good, But if i don't like it does it just peel off or buy a new grill ??? thanks
purple 'hoe
Green Bay, Wisconsin
Plasti-Dip can peel off
I sprayed my grill inserts, not my whole assembly. Never took it off. Never have had a issue since. Only did a light coat however. Just enough to make it look darker I just masked off what I wanted dipped and what I did not want done.
Used it on my front bumper cap and valance. Gonna have them redone correctly though. Looks terrible IMO. Plasti-Dip is nice for somethings, but not everything.
Y
yooks11
So instead of using the PD for my grill, I ended up putting some coats on the new wheels I just got. Put four coats on but didn't let them dry for long enough so one wheel peeled as I was loading it into my vehicle. Going to redo this wheel and add 2 more coats to each of the others.
Once all this is done, I'll be PD'ing my grill.
Goodinblack
I Like Tacos
Dirty South
The is a very small learning curve with PlastiDip, but once you get going.......
AZSCTACO
Phoenix, AZ
Here is mine......
DaveBYukon
