LED Bulbs Questions?.?.?.?.....
wht06shee
Ive Searched and havent really found alot of info on the led bulbs for the 07+ tahoe, wanting to do a Bright reverse, license plate, puddle lights, front turn signals, drl, and interior lights, but havent seen much pics, i dont know where to buy them at, and what numbers everything is.
so any info would be appriciated
thanks :party36:
stevek
Dallas, TX
I just bought some last week... haven't put the interiors in, but on superbrightleds...
The ones I used for puddles and license plate are (get 4):
WLED-xHP15-TAC: 194 LED Bulb - 15 SMD LED Wedge Base Tower| $ 6.95 |
WLED-CWHP15-TAC: Cool White
For interiors (not installed) I bought (Get 6):
4410-x9: 578 LED Bulb - 9 LED Festoon | $ 4.74 |
4410-CW9: Cool White
Thanks for the thread start though, I just realized I only bought 4 interior bulbs instead of 6 :(
EDIT:
If you want pics of how they look on my plates or the puddles, I can take some later
wht06shee
wht06shee
EDIT:
yeah and can you get some before and after??
if a moderator see's this can you do a sticky so it will be avalable for everyone to view it, so people wont have to go threw these same steps to figure out whats what??
---------- Post added at 07:17 PM ---------- Previous post was at 07:03 PM ----------
heres threw sylvania website
Low beam headlight-H11
High beam headlight-9005
Parking light-4157NA
Front turn signal-4157NA
Rear turn signal-3057
Tail light-3057
Stop light-3057
High mount stop light-LED
Fog/Driving light-5202
License plate-2825
Back up light-7440
Front sidemarker-2825
Map light-212-2
Dome light-212-2
Trunk/Cargo area-921
Daytime running light-3157
threw superbrightled
Daytime Running Light
Part Number: 3157
Fog/Driving Light
Part Number: 5202
Front Sidemarker
Part Number: 2825
Front Turn Signal
Part Number: 4157NA
High Beam Headlamp
Part Number: 9005
Low Beam Headlamp
Part Number: H11
Parking Light
Part Number: 4157NA
Back Up Light
Part Number: 7441
High Mount Stop Light
Part Number: LED
License Plate
Part Number: 2825
Rear Turn Signal
Part Number: 3057
Stop Light
Part Number: 3057
Tail Light
Part Number: 3057
Dome Light
Part Number: 212-2
Map Light
Part Number: 212-2
Trunk/Cargo Area
Part Number: 921
stevek
Dallas, TX
I mean search google for before images, I can get pics in a few days... don't have my Denali right now
Megaboom
So which ones are the most popular ones for daytime running lights? I know it's a 3157 bulb but there a lot of different styles to choose from
wht06shee
wht06shee
well i havent bought mine just yet, but gunna have to run a resistor for the drl, im gunna order mine threw super bright leds
stevek
Dallas, TX
Sorry for the late reply, I just installed the bulbs today. Unfortunately I ordered two too few for some reason, my mind was in another place when I ordered them.
http://www.tahoeyukonforum.com/forum/album.php?albumid=2378
Don't worry about the low angle of the front LED bulb. It was aiming straight down, all that was needed was to turn the bulb outwards and it's perfect. Lights up the cabin just as well as the ****** stockers :)
glockz
Is anyone running LEDs for the low beam? Recommendations?
vt_hokie2008
VA
I would NOT run LED in the low beams. You won't be able to see anything b/c the light will not be projected far at all. For low beam you can either do a retrofit with projectors and HIDs (best option), HIDs without projector (brighter than stock but many people don't like this) or go with something like Silverstars.
Fair Oaks, CA
I just purchased and installed the interior lights and the license plate and puddle exteriors. For my reverse lights I got a couple CREE bulbs which are awesome and I highly recommend them. On the superbrightled website, it shows the map and dome lights as the same festoon bulb but the cargo area as a wedge base. For my particular vehicle (2008 Yukon XL) this is actually incorrect. The cargo light uses the same festoon bulb as all the other interior lights. So if anyone is ordering these lights, they should buy 7 of the 212-2 Festoon bulbs, not 6.
Another issue I ran into was for the puddle lights. I got the same bulbs as the license plate lights but they dont seem to fit quite right. I think it might actually need a different bulb but I'm not sure what. If anyone know, let me know!
wht06shee
wht06shee
i just ordered drl, front turn signal, resistors, license plate, puddle lights, reverse. when i get em ill see how it all goes!!!! :happy160:
vt_hokie2008
VA
What type of bulb did you get for the drl? Regular LED bulbs will blow pretty quick in the drl, others have had great success running dual circuit bulbs though.
glockz
Thanks! I will look into those options.
stevek
Dallas, TX
I had no problem with using those bulbs... they were interchangeable. Which ones did you buy?
What 7th light are you talking about?
Fair Oaks, CA
I purchased these guys: http://www.superbrightleds.com/more...194-led-bulb-15-smd-led-wedge-base-tower/910/
While they do indeed work, they're too loose and easily fall out of the socket. I've ordered two of the following to replace them: http://www.superbrightleds.com/more...led-bulb-5-smd-led-wide-angle-wedge-base/206/
The base looks closer to the stock bulbs so I'm hoping they'll fit better.
In regards to the 7th light, it might only be on the XL/Suburban/ESV. It's a 7th light in the rear cargo area. According to the superbrightleds website, it shows a wedge-based bulb for the cargo area but there is no such housing for them. Instead it's just another of the festoon bulbs just like the others.
stevek
Dallas, TX
I ordered those same wedge bulbs and they worked fine... weird.
Unless I'm blind there definitely is no 7th light on the regular length
Fair Oaks, CA
Yeah they definately don't fit right in my mirrors. I'll take some pictures when I make the swap out. I also ordered some SMD interior leds from iJDMtoy.com to compare to the superbrightLEDs. I'll do a write up on them once they're received.
As to that 7th light, it must be just on the Suburban/XL rather than the regular length. What's sort of weird about it is that it only contains one lightbulb whereas all the others have two bulbs... Anyways, once I do the switchout I'll take some photos for comparison and toss them up.
Buford bubba
