Which gas for the 6.2L
DStockton
Do you all run Premium (91 where I'm from) or reg (87) and can you tell a difference in mpg and power?
THE YETI
Director of Operations
South FL
I believe the 6.2 requires premium gas. Not sure why youd put regular in it. I think that can be harmful to the engine.
totheyard
2 dealers told me 87 was fine. I asked the same question because of what the owners manual states. I have not put 91 in it to compare.
doubletapdrew
From the owners manual:
Use premium unleaded gasoline with a posted octane rating of 91 or higher. You can also use regular unleaded gasoline rated at 87 octanne or higher, but the vehicle's acceleration could be slightly reduced, and a slight audible knocking noise, commonly referred to as spark knock, might be heard.
If the octane is less than 87, you might notice a heavy knocking noise when you drive. If this occurs, use a gasoline rated at 87 octane or higher as soon as possible. Otherwise you could damage the engine. If heavy knocking is heard when using gasoline rated at 91 octane or higher, the engine needs service.
I notice a slight decrease in accel when using 87 but it could just be in my head.
THE YETI
South FL
I'd hope they have your back when you bring it back with potential issues. My bet is that they'll deny everything.
That engine should use premium, I'd recommend it. As posted above, you could notice issues if not.
:Handshake:
totheyard
:Handshake:
I agree! But it is recommend, not "91 only". Higher end vehicles state 91+ only. I hear zero knock, but i am sure it would run better on 91. But if it blows up running 87, then we could win that fight pretty easy. They shouldn't write it in the manual as a guideline.
Gzes
the drifting 2dr
Wichita tx
Be safe pay the extra couple of cents you drive an suv your already paying a good chunk of change for gas so just get premium
totheyard
I kinda want to, but ****! Why can't they just pick one octane for the 6.2. What does the Camero use? Why pay more when the 87 is ok?
THE YETI
South FL
Thats like saying why pay more for a Denali when a regular Yukon is ok?
LOL...
You do it because you can afford to treat your baby right! Give her the Heineken, not the Pabst Blue Ribbon!
I'd put nothing but premium in it
totheyard
LOL...
Yeah I guess your right! But I can get pretty shit faced for cheap on some Pabst!
purple 'hoe
Green Bay, Wisconsin
Don't take the dealers word on everything they tell you. This is coming from someone who works at a GM Dealer
If something is "recommended", then it's usually what they want you running for fuel. I'd run 91+ if it was me.
downforce137
http://www.economist.com/blogs/babbage/2012/09/octane-ratings?test=babbage
To sum up, if the car’s handbook says that premium petrol is “recommended” (rather than insisting it is “required”), then the engine will automatically adjust itself to run smoothly on a lower octane fuel. Because of the retarded ignition, the engine will, of course, produce less power, and have slightly higher fuel consumption. But the poorer fuel economy is likely to be outweighed by the savings at the pump.
07Denali
I prefer Schlitz. I run 87 in my 2012 Denali and it has what almost sounds like a lifter tick or small exhaust leak. May be some ping. I am going to try mid grade (89) fuel and see it gets any better. Any "loss of performance" I would assume is negligible and will still have more power than the 5.3 in the tahoe we were looking at.
stevek
Dallas, TX
If it lowers my economy by 1/2mpg, it's cheaper to put in premium than buy the extra gallon
skippy737
NW IN
Nothing but premium for three years, whats and extra .20/ gallon or $5.20 a tank.
We buy these vehicle for everything BUt fuel economy
briannorris
