Green plug - front end area
gasser76
Ocean Springs, MS
Hi there,
Does anyone know what this plug is used for? I saw it tucked away up the radiator and pulled it down for the attached picture. Having a tricky time tracing it back to something.
I am wondering if it's part of the SSV wiring that GM did; but can't confirm it.
Thanks,
-graham
Wake
Stafford, VA
You have an airbag light on or an airbag code?
I replaced one of my front impact sensors not too long ago and I think it was a green plug. It looks about right area for it to be.
G
gasser76
Ocean Springs, MS
No lights or codes. I know what you are talking about, I believe. There are two little boxes, mounted below the radiator - one on each side with a little airbag picture on them. Both of mine are plugged in already, however.
G
gasser76
Ocean Springs, MS
That looks like the fog light plug.
That is what I was kinda hoping for. However, I only see this one plug.
For the trucks that were equipped with Fog lights, where there a connecting harness that connected the lamps then to this plug maybe? Truck didn't come with fog lamps, but I do have a 2nd valance with the fog lights and have a generic harness (with a toggle switch for the cab), but if there is factory wiring to be used - maybe that is a better route? Thanks!
---------- Post added at 07:10 PM ---------- Previous post was at 06:48 PM ----------
I just found a GM all-in-one kit that includes the factory harness, lamps and the replacement switch for the cab. Says it uses the existing wiring. GM part # is 17802547. Does anyone have any experience with this kit?
brice715
