95 tahoe 4x4
swarren
I wanted to know if My 95 2 door tahoe 4x4 is towable behind an rv with all 4 wheels on the ground?
Donnie Yukonie
Yates Caretaker
i dont think so, i know there is some speed limits you cant exceed and i would imagine you would have to remove the front drive shaft , possibly both, and i would buy some sort of steering wheel lock device
S
swarren
Damn I was hoping that wasn't the case. My wife and I will be full time rving and Need a towable 4x4 and I was wanting to tow it.
BattelWagun
Chi-Town USA
You would need a way to disconnect all 4 wheels from the drivetrain, or else you might cause damage.
Although I never understood how that could cause damage...
S
swarren
I don't understand it either. I was really hoping to be able to take my tahoe with us.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Yes you can because you have a '95 you should have a floor shifter. If so when you put it in neutral(not the tranny) you disconnect the both front and rear axles from the rest of the drive train. Just beware to only shift the tcase to neutral after it it is rigged to rv and secure. Because the only thing holding the truck still is level ground(I hope) and your foot on the brake. And remember to release parking brake on truck if used before driving tv. There are no speed limits except in relation to the towing equipment itself.
S
swarren
Thanks Sunlit. I wasn't sure. I tried google and damn thing apparently doesn't know everything.
SunlitComet
OBS Jedi-Do Good
No drive axle disconnection needed but keep track of mileage for more frequent service fluids in tcase and axles compare to rest of vehicle not used as much. A quality towing kit should have everything you need including wiring up the hoe tail lights to interface with the tv.
---------- Post added at 10:43 PM ---------- Previous post was at 10:42 PM ----------
You do have a floor shifter right?
S
swarren
Gotcha. It does have a floor shifter. Where would a good place to get a tow kit.
Donnie Yukonie
Yates Caretaker
opps sorry i didnt mean to mislead you i didnt account for the 95 part haha
BattelWagun
Chi-Town USA
You can put the push button transfer cases in neutral as well. I had to on my 99 when my sunshell erupted and locked up the tranny. I believe you just put the tranny in neutral, apply brake, and hold down 2hi and 4lo buttons for five seconds. I guess all the obs trucks are towable!
SunlitComet
OBS Jedi-Do Good
Only e-shifters that are np8 nv246 tcase starting in '98 can do that. The '96-'97 np1 nv243 can not. It sucks but '96-'97 lost the neutral option.
noJeepshere
Bountyfull, Utahrd
I was going to say: "Read the owners manual!" that kind of stuff is in there for this purpose. But then the encyclopedia chimed in and everything is good.
---------- Post added at 09:11 AM ---------- Previous post was at 09:09 AM ----------
typical of an autotrac owner.
Hopefully one day my autocrap will be replaced with a floor shifted t-case.
SunlitComet
OBS Jedi-Do Good
HEY!, who you calling encyclopedia, book excerpt!
oh and when it does you have an open invite to send me all the components you replace. i am working on a design modification for the np1 nv243 system. I want to convert it to the np8 nv246 auto4wd autotrac system. I could use all the parts i can get donated to keep costs low.
noJeepshere
Bountyfull, Utahrd
:D I'll keep that in mind, though it likely won't be for a while, I've got other things going on, like school all next year.
SuburbanPassion95
