transfer case oil
ericnj75
i have a 01 denali xl awd what oil should i use when i change it?
Dahlar
All tahoes/yukons/denalis use the GM AutoTrak II fluid. It is available at any chevy/gmc dealership and for me ran about $8 a quart and I think it was 3 quarts for a full change when I did it. I haven't found or heard of an alternative fluid for the transfer case either.
NathanJax
Vacation Nathan
Jax, Fl
Royal Purple Synchromax
http://www.royalpurple.com/manual-transmission-fluid.html
I switched my transfer case fluid out a couple weeks ago for Royal Purple Synchromax and at the same time, did my front and rear diff's with Royal Purple Gear Fluid
TheFuzz
Idiot Police
Spurbury, VT
I don't think that ATF is supposed to be used in the T-case, it's a special fluid that GM puts out.
The GM Autotrak fluid aka "smurf juice" is the only thing that meets the GM specifications AFAIK. Maybe you'll prove us wrong.
NathanJax
Vacation Nathan
Jax, Fl
Edited my first post.
I called Royal Purples tech support as well before doing this. We swapped out all the fluids at my fathers (mechanic) shop, so if something happens, he'll be rebuilding the tranny and we'll go ahead and beef it up at the same time.
Royal Purples website says...
Synchromax is recommended for manual transmissions that specify an automatic transmission fluid. It’s also ideal for 4×4 transfer cases and motorcycle gear boxes. Synchromax is fully compatible with all types of friction materials. It provides excellent corrosion and oxidation protection without affecting the soft metals commonly found in manual transmission synchronizers.
Robert.K
San Diego, Ca
x2 on the royalpurple, did my transfer cases and differentials too with it, and have the power steering, trans, and oil. the whole line in my Truck! High recommended and have had no problems. but I do think the next oil change i get I will switch up 10w30 instead of the 5w30 im running now. Seems to thin.
E
ericnj75
my repair manual says that 149np is to use dexron III atf is this right?
brice715
