Help!!!
pjay
tx
In my 2004 yukon all my gauges work except for the mph gauge and half of the gauge the light is faded out.can it be a fuse i look under the hood put couldnt find the right fuse. Wasnt sure which one it was.can you please help i dont know how fast im going when im driving
thanks
does any one know where this fuse is at?
OKLAGMCRUISER
Need drop...send $
Kiefer, OK
194 bulbs in the cluster might need replacing and as 2000yukon said...stepper motor issue is possible.
NathanJax
Vacation Nathan
Jax, Fl
Like everyone mentioned... light out and stepper motor.
nope... he has a 2004 which means they are LEDs...
OKLAGMCRUISER
Need drop...send $
Kiefer, OK
um...my 05 has 194's in it! they are installed inside a 194 twistloc socket. there are 5 or 6, iirc that back light the cluster.
NathanJax
Vacation Nathan
Jax, Fl
Are you sure?
That's only 99-02 that do that. 03-06 are LEDs...
My 01 HOE had twistlocks, but my 04 they are soldered to the board...
Here's the 99-02 guage where the 194 twistlocks go
This is what the 03-06 gauges look like and you can see the LEDs
here's plenty of threads about it
http://www.fullsizechevy.com/forums...nterior-tech/301011-03-blue-led-write-up.html
http://www.gm-trucks.com/forums/index.php?showtopic=90108&hl=stepper+motor
http://www.gmfullsize.com/forum/showthread.php?t=159553&highlight=cluster
http://www.gmfullsize.com/forum/showthread.php?t=24726
http://www.gmfullsize.com/forum/showthread.php?t=147987&highlight=cluster+led
http://www.fullsizechevy.com/forums/4092985-post22.html
http://www.fullsizechevy.com/forums/4103932-post29.html
OKLAGMCRUISER
Need drop...send $
Kiefer, OK
idk then...i must be wrong...sorry...oops...don't tell my wife i ever admitted that...lol.
strange thing...i can only see the 99-02 pic here at work...lol...and can't go to any of the links as work hsa them all blocked too...thnaks for the clarification. i don't know everthing....juts a bit about a lot...lol.
i guess i just assumed they were all the same and had it in my head i was 100% right...hehe.
NathanJax
Vacation Nathan
Jax, Fl
No worries...
:Handshake:
(And I just emailed your wife your posting. Sorry) :laughing1:
OmarR
Indianapolis, IN
Nathan, you are correct that the 03-06 are not twist off 194's, but they are also not LED's.
If you look at your 03-06 pic, you can see all the mini bulbs with blue bases piled up at the top of the pic. That pic is actually a write up of switching over to LED's.
If you are good with a soldering iron, you can just buy mini-bulbs at Radio Shack and solder them in on the 03-06 clusters.
rossida
