99 hoe bogs down in mud??
felskee
well when i go mudding and need to reverse it bogs down. not losing rpms or anything it just has no power and it stays at a certin rpm. put it to the floor no change. in drive it does the same until you get on it then its not that bad. im thinking it has to do with the gears? 3:42 on 33
Gzes
the drifting 2dr
Wichita tx
Might wanna clean ur throttle body. I would also look at getting a tune up ajd does ur hoe have lockers?
felskee
felskee
its a brand new motor less than 10 k and nope
SunlitComet
OBS Jedi-Do Good
unknown at this time.
you reverse gear ration is probably playing the biggest role in that although 3.42 gearing may not be helpful either.
1st: 3.059
2nd:
1.625
3rd:
1.000
4th:
0.696
Rev:
2.294
---------- Post added at 01:32 PM ---------- Previous post was at 01:30 PM ----------
you only get one reverse gear ratio unless you kick in the low t-case gear.
felskee
felskee
and when im on pavment from a dead stop its kinda boggy wierd feeling till about 10 mph
---------- Post added at 01:42 PM ---------- Previous post was at 01:42 PM ----------
i hope its just the gearing
purple 'hoe
Green Bay, Wisconsin
33's, 3.42's and mud. You do not have enough gear for the tires as is, and when you throw mud into the equation, it only makes it worse. Needs more gear IMO
I had 3.73's in my Tahoe with 33's and thought that I did not have enough gear. Mine would bog sometimes if I got into something deep or when climbing rocks
Donnie Yukonie
Yates Caretaker
gears i think are to blame here you have to equate the weight of the mud itself soupy mud acts as a suction on your tires thus slowing it down slap 4.56 under that bad boy and hold on the engine doesnt have anything to do with it as v-8 provde enough torque , take a lesson from a 4cly jeep with 35 or greater tires all they do is regear
purple 'hoe
I'm assuming he uses this truck often for mudding if he is bogging down in mud.
You want to regear for your terrian and your tires when it comes to off roading. 4.56's+33's (op stated 33's) would be good for a mud set-up. It might suck on the street, but theres no fair trade off here
Could maybe run a 4.30 if that's available for his truck. Not sure if it is however
_Dylan_
STAY FROSTY
Check the fuel pressure that might be making it bog down.
Donnie Yukonie
Yates Caretaker
Ive done a TON of mudding in my truck and i can assure you if its only happining in mud its gears related , purple is right here with the no fair trade off , while you will notice a def increase in torque and feeling of power and wheel spin . gas mileage decreases with a regear . mine does it all the time since i have not yet regeared 4.56 is a bit much for 33 as its a near perfect match for a 35 but if you mud often im sure you are thinking of lifting and bigger tires in the future 4.10 gears would be OK also for 33s but you will run into the same issue once you go to a 35, use this chart http://www.offroaders.com/tech/gear-ratio-chart.htm , remember i said 4.56 almost perfect for overall.
lets just drop a 5.71 ratio under it with 44s =)
felskee
felskee
Well i use mine as my dd since im still in hs lol. I plan to get some 35's soon but moneys the issue when it comes to the damn gears, been quoted 1500+ for front and rear and stock size tires were i think 265 .... 15
---------- Post added at 08:34 AM ---------- Previous post was at 08:33 AM ----------
And yes i eas looking at 4:56 for my futre 35's
SunlitComet
OBS Jedi-Do Good
if your stock tires were 265/75/15 and current gear is 3.42, the when you switch to 35 you would need a 3.91 to re equal the given RPM in Feet Per Minute. this would basically return the stock rwhp to ground but does not take tire mass into consideration on acceleration rate. if this is a vehicle that sees any road time then i would suggest 4.10 for street and using the transfer low modes and gear 1, 2 or 3 for mudding. it is the compromise that seems to make both sides of equation happy for power and mileage.
---------- Post added at 11:54 AM ---------- Previous post was at 11:53 AM ----------
if you have different measurement you want to try let me know.
felskee
felskee
well i dont want it back to stock... hahah i cant stand this sluggish / no power. thats why im saving up for some 4:56s to get put in for a steep 1500..
Drewphil
