GM Cold air kit
RoliO
Dallas, TX
This beauty arrived yesterday. Going to install this weekend. Hopefully it was a good investment. :)
OHSIXX
Milwaukee
You will like it-I like mine ;) Easy to install and fit/finish is great ;)
R
RoliO
Dallas, TX
Well I decided to jump right in after I posted this thread this morning. Started at 10:35a and by 11:20a I was done. And this was with a 5 year old and a 2 year old that kept coming to the garage to ask me if I was done yet. Install was really easy. I only had 1 extra part (pic below) that I did not know where it went. The instructions were ok but the images (B&W images) supplied were a bit difficult to make out. Regardless I have installed cold air kits on several of my cars so I had an idea on how it went in. :D I took it for a spin around the block and there are no engine lights on. Everything looks GTG.
Before
After
The extra part (grommet)
---------- Post added at 12:04 PM ---------- Previous post was at 12:00 PM ----------
The hose that runs from the radiator to the overflow tank sits above the MAF sensor. I tried to re-route it through the bottom but it was about 3" too short. It would look a lot cleaner if this was was re-routed. Maybe I'll do that next.
R
RoliO
Dallas, TX
How much?
A buddy of mine works in the parts dept at a GM dealership. Got this cold air kit, 8 OEM plugs, and the 2 engine belts for $300. :D I figured the price for this alone was about $250'ish. I told him I could sell him a couple more of these cold air kits if he'd let them go for $250 but he said no, lol.
Anyhow just went for a drive and first impressions is WOW. The SOTP meter says this was a good mod. When I step on it there is no hesitation...it goes. I need to do the plugs here in the next couple of days. My Tahoe has 80K miles.
Okiedave
Oklahoma City
I think that part is a grommet that a the radiator overflow hose goes through.
I have a K&N and I went out to see what the grommet was for on mine. Well I can see where it was, but it is missing and the thin metal is starting to work it's way into that hose. I am going to have to do something about that shortly. Glad I went and looked.
Okiedave
Oklahoma City
Btw I really like the way that looks!! The K&N is on my 01 Yukon, I might go this route on the 04 Denali.
R
RoliO
Dallas, TX
There is no way the radiator overflow hose will go through that grommet. The grommet inside diameter is about 1/2". The radiator hose outside diameter is about 1". Hopefully somone with this kit will chime in. You have me worried now.
---------- Post added at 06:48 PM ---------- Previous post was at 06:44 PM ----------
By the way, the instructions tell you to install the 90deg elbow on the TB and then to install the other 90deg elbow on the MAF sensor. Then to install the polished piece between them. This would have been a PITA. I installed the elbow on the TB then the polished piece to it. Then the other elbow to the polished piece and then slipped it over the MAF sensor. All the clamps were a bit loose so I could rotate as needed until everything was aligned. Then I tightened them all.
Okiedave
Oklahoma City
Did not intend to get you worried. I am glad you posted and that I went to see where the one I was thinking of went. Not sure what else that might be for. In my kit there were several large rubber washers that are used as vibration dampeners use between mounting pionts and the filter box used on the mounting bolts.
fire730
Louisiana
The gromment isnt for the tab that sticks out on the box in the first pic?
I dont think I would reroute that coolant hose under the intake tube. That may cause a problem with it sending the overflow coolant back to the tank.
R
RoliO
Dallas, TX
No the grommet is not for that tab. On that unit you have to remove the stock mounting piece and put it on the new one.
After thinking about the overflow hose I would tend to agree with you and will probably just leave it alone.
---------- Post added at 09:24 PM ---------- Previous post was at 09:22 PM ----------
No worries man. I just hope it doesn't go somewhere important. :D
fire730
Louisiana
Is that grommet for the older trucks that had the filter service reminder?
There isnt a random hole in the side of that airbox is there or somewhere to drill a hole?
R
RoliO
Dallas, TX
I think you are right. I remember reading something about the filter check in the instructions and then drilling a hole for it. Maybe it went there. But since mine didn't have one i skipped that part. Thx!
Modded
That Guy
Looks good. I like how the filter is boxed up from the elements.
What did you do with the hose that connects to the intake tube part that goes under the engine cover?
OHSIXX
Milwaukee
Looks good and what a steal on the $$$ for this and the other parts---it pays to have the right people in the right places ;) The grommet is for that filter 'minder that I also didn't install-looks wayy cleaner without it.
R
RoliO
Dallas, TX
That hose you are talking about is the valve cover breather hose. The kit came with a hose about a foot long. That hose is to connect the valve cover breather hose with the little pipe attached to the underside of the polished intake. The supplied hose a waaaay too long. You only need about a 4 inch piece.
Modded
That Guy
Ok that's what I thought. My intake tube has the same layout.
ZaZaZazzels
