door latch issues
JubjubW
Wausau, WI
So my rear drivers door had some issues opening unless you hit the unlock button at the right time. and for a while it wouldnt even lock, but now it works like it should with the locking mechanism, however you cannot open it from the inside, just the outside.
After a can of WD40 and some monkeying around I decided its the latch mechanism itself, and I am assuming the lock/latch are all one unit? thats my conclusion after beating my knuckles up...
if so, does anyone know where I can find a replacement? I am having a hard time locating one and I dont want to replace the door because of my graphics package
turk
I believe you are experiencing a fairly common problem /weak point with Chevy trucks... my tahoe and my 97 3/4 ton had the same issue. If I am understanding your problem correctly you will definitely have to replace the assembly. There are several places online where you can purchase the assembly.... I'd try Amazon.com. I believe that O'Reilly or Autozone can get you the part as well.
I'm not sure of your application/color, but I believe this may be close to what you need... http://www.amazon.com/Chevrolet-Pickup-Drivers-Inside-Interior/dp/B002XYZYBG
---------- Post added at 11:50 AM ---------- Previous post was at 11:48 AM ----------
This may help as well.... http://www.youtube.com/watch?v=7kHHz7gzT-Q
JubjubW
JubjubW
Wausau, WI
thanks turk, but I already replaced the interior door handle, it was originally broken off.... so i drilled out the old rivets and put in new ones for the new handle. The latch i am talking about is the one on the side of the door that actually holds it shut, I am curious if that is one whole unit with the locking mechanism/power locks
ssrado85
Galveston
Im having the same problem with my drivers door Just havent had a chance to look at it, Mine actually messes up to where the door unlocks but I still have to manually unlock it from the outside in order to open the door total pita and i look stupid unlocking my truck with the key while im in it :emotions122: Im out of town so I can tear into it but any light on these situations would be great!!
turk
Gotcha... sorry. I will be absolutely no help then as I have not experienced that..... yet.
JubjubW
JubjubW
Wausau, WI
lol! no problem turk
ssrado85 -
I havent had any troubles like that with my front doors but the mechanism looks completely different then the back
ssrado85
Galveston
ssrado85 -
I was thinking it was the interior handle not pulling the latch far enough but I replaced that. It seems to me like it has something to do with the latch itself
WalterMitty
Oklahoma
Forgive my impertinence, but make sure the child safety selector hasn't inadvertently been activated or partially bounced out of position. :)
ssrado85
Galveston
In an earlier post I said I had to hang out of the car to let myself out. 2 door. I just said driver's door and figured it would be understood since I didnt say the rear "driver's side" door. Sorry for the confusion.
[/IMG]
JenneK
Island of Maui
Highjacking someone else's thread creates confusion for those trying to help the OP. Prevent confusion; start your own thread. :)
ssrado85
Galveston
Not trying to Highjack I am having similar problems so Im interested in what everyone says.
JubjubW
JubjubW
Wausau, WI
havent checked this in a while lol! On my way to work I will check the child lock, I may have bumped that messing around with getting the WD40 straw in the right spots.
JubjubW
JubjubW
Wausau, WI
the child lock was not on... and the only door latch i could find was on LMC for $150... at this time its not worth it in my opinion since the door opens from the outside and locks fine... the baby seat can sit there
dizhai
