Getting rid of slop
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Hey tony do you think this kit will get rid of the loose rear end I feel when hitting bumps in my XL??
how is it lowered now?
---------- Post added at 08:18 AM ---------- Previous post was at 08:18 AM ----------
How is your own setup coming along, I mean the bars you are working on........
ended up scrapping it due to cost
06xl
MD
@ NorCalSS its not lowered at all but it's horrible when I hit a bump at highway speeds feels like the rear wants to fish tail.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
do you have autoride in rear of your truck?
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
invest in the djm bar along with the spohn rear kit. Im wondreing if your stock rubber bushings are toast which doesnt help at all.
04blackout
Im interested in doing this as im trying to finally dial my suspension in... so how many of what size bolts do I need here? Is it just the 4 bolts or is that for each side? Would like to just make a quick trip to lowes after work and get rid of the slop
Rpav
Fontana, CA
If I understand correctly you are selling the larger bolt kit for the sway bar. Let me know how much bro. Thanks!
guy from norcal
Tony,
These are the bolts that come with the kit, or these are the bolts that I should go out and get in grade-8?
If you could just make and post a quick list of bolts (diameter, length, etc.) -- how many of them, and where they go -- that I should go out and get in grade-8, that'd be great.
From your post above, it sounds like that's what DJM includes, but that you recommend UPGRADING to something different.
Maybe that list above IS the list of bolts you recommend, just in grade-8 grade...?
Thanks.
I think it's 2 1/2x2 3/4 for the top sway bar end link. one each side. Mine had a 1/2 on the bottom already.
And 4 9 1/6 x4 1/2 for the lower trailing arm.
I only did the one on each lower trailing arm since i only bought 2. Need to buy 2 more.
Candielaine
