trimming plastic fender wells
chadman
I've got Tony's 2/3 belltech kit with 305/40r 22's on kmc slides.
I've got 2 problems.
1. both front fender wells are rubbing when turning. Is the fix to heat them up and bend them in somehow?
2. both rear fender wells are rubbing when the Tahoe enters an uphills slope when all the weight it shifted to the rear. I've had the fender wells trimmed, but I think I need them trimmed more. How much have you guys trimmed off? And note I first didn't have the rear spacers in and it was really rubbing. After I put the rear spacers in, its not as bad, but still rubbing.
Attached are some photos
thanks.
NORCAL SS
SUV SUSPENSION GURU
ill post up mine tomm. i took off a lot more and in front ive been using my little mod for years and works perfect. PM me ill shoot you all info.
chadman
chadman
anyone got any photos of their fender wells so I can compare?
NORCAL SS
SUV SUSPENSION GURU
Im coming back from the street races with my car on the trailor. Once i get it off ill take some pics so you can see.
lx4life
I actually I just pulled the liner in the rear with zip ties and it has helped the rubbing and i am running 305 35 24s.
felixgun
Lafayette, LA
OP I know this is off topic but can you take some pics of your running boards and post em? :)
emay
S. Elgin, IL
For your rears I think you trimmed off enough those bumped out sections that are catching are common and are an easy fix. I have a monokote heat gun that I use to get em nice and soft and I press the bump out until it's basically inverted. I use the handle end of a rubber mallet to push them.
While still warm the plastic will try to revert back to it's original home, but if you keep them pressed for a minute or two of cooling they will stay without issue.
I have minor rub up front with the esky reps only at full lock so I haven't done anything with those.
VTburban
Vermont
Erin I can't get over your truck. She's so f-ing DIRTY!!!! Love it.
emay
S. Elgin, IL
Thanks VT - I gotta go get some shots in a fresh setting.
I was checkin your thread on the TBSS add on. I like the look, set up real nice with the contrast in color from the body. Nice work your self.
rosendo192000
FrontLeft ( rear of wheel)
26" with a 2/3
chadman
chadman
anyone's pics :) just to compare so I know how much more I need to trim off.
NORCAL SS
SUV SUSPENSION GURU
Im headed back from chicago on the plane now from our national tbss event. If its not dark when i get home ill take a pic of my rear fenderwells.
Fearz
Houston
How did you all do the cutting. Did most just take a Saw and get to work or?
NORCAL SS
SUV SUSPENSION GURU
I used a 4 inch cut off wheel but you can use a exacto knife
glazar
