Grease ring on inside of left rear wheel?
drkhrse00
Dallas Texas
I have noticed a grease ring on the inside of my left rear wheel and you can smell grease after driving an extended period of time. Any suggestions before i rip into it? No noise when driving. Just a small mess and smells.
drkhrse00
drkhrse00
Dallas Texas
Gonna rip it apart on monday. Hoping its just the seal. Bearing worst case. Like I said no noise or vibrations. Just small amounts of grease and the smell.
---------- Post added at 10:23 PM ---------- Previous post was at 10:15 PM ----------
Any posts of a walk through for replacing axle seals and bearings?
fire730
Louisiana
Do you have access to a slide hammer?
Also the first thing that you need to focus on is getting the 5/16" bolt loose that holds the C clip lock pin in place. I've had them break before when trying to remove them. If it breaks off then you aren't going to get the axles out unil you get that bolt out. So don't waste your time fooling with the brakes until you get the lock pin bolt out. HTH
fire730
Louisiana
fire730.Where can you get this bearing assy.Up here in the frozen north no one seems to know anything.
The link above was for SKF but this is by National.
This is from ROCKAUTO for an 04 Yukon XL
NATIONAL Part # RP513067 More Info Axle Repair Bearing; Bore=1.618", Outer Diameter=2.842", Width=1.165"
Rear Wheel; Axle Repair Bearing
$37.79
And here is a good pic of a axle saver bearing.
http://www.rockauto.com/catalog/moreinfo.php?pk=221809
Hope this helps some.
drkhrse00
drkhrse00
Dallas Texas
I got it taken care of new seal,bearing, and fluid. Axle was in good shape. Did a fan clutch while i was at it.
fire730
Louisiana
Glad you got it fixed with no axle problems.
Also why in the hell dont they make wheels like those Modas anymore? My buddy had a set on his Explorer. Sick wheels!
Big Jim
