map lights leave me puzzled :-(
TOWRIGG
BX. NEW YORK
did my interior led's today on my 03 denali and love them but im a little baffled as to why the map lights arent as bright when used individually as to when turned on with the rest of the interior lights....my boys tahoe does the same thing. is there less power to them when used with the button as opposed to when turned on with the rest of the lights with the switch?? when i turn the second light on via button the first one dims as well as the second one coming on dim....but no where near as bright as when switched on or door opened....any idea's why this is??? thank you...
Rivieraracing
Alot of us have been through that that have switched to LED's and it was quite an experience to how we solved it!! Basically, the normal bulbs draw quite a bit more current, and when you switch on a light manually, the draw kicks on another circuit which gives the light full power! When you switch to LED, the draw is practically not there, which is the reason you only get half lit LED's!!
What you need to buy for every light that you can switch on manually with a switch is the CANBUS style LED bulbs for each!! The canbus style bulbs have a built in resistor in them which solves the problem in a heartbeat!! We tried other ways to solve it and they worked as well, but this is indeed the easiest solution!!
So basically, would need to buy them for the first row map lights, second row dome lights, and the vanity lights in the visors if those bug you with only being half bright!!
Here's an example of what I bought for my map lights!!
http://www.ebay.com/itm/2-CANBUS-T1...Parts_Accessories&hash=item2a19991aa9&vxp=mtr
TOWRIGG
TOWRIGG
BX. NEW YORK
i gotcha....had to get canibus led's for my clk...thanks for explaining that,really makes sense and cleared that up. i now know what must be done..lol hope they match the rest of the lights...lol appreciate it much
Rivieraracing
I bought mine through the same seller, helps insure that they will pretty much match!!
TOWRIGG
TOWRIGG
BX. NEW YORK
i have these on my switched domes and theyre crazy bright....was thinking of using them also on my second and third row maps...do you think i should get them canbus style or just the same as i already have?
Rivieraracing
If they have their own manual switch to turn them on, then I'd get them in Canbus, otherwise the others only turn on with the interior lights and you will never have the dimming problem with them!! Just make sure that bulb will fit in the lights you are talking about before assuming that they will fit!
Suburbinator
San Marcos, CA
I've been running a similar style from Superbrightleds.com for years in my '02 and just put them in my new Burb too. All the roof lights have been converted and there's no weird behavior, just nice and bright.
Rivieraracing
A while back when I was helping a few guys on here solve their dimming problem, everyone thought it was only a '03 and up problem at first. Then I decided to buy enough lights to do my '02 denali and low and behold my truck had the same problem!! Crazy how mine did because some other guys with '02 and lower didn't have a problem at all!! It also didn't matter for the guys with the problem whether they bought the cheap Ebay bulbs ( like i did) or the superbrights, their lights still dimmed unless they went with canbus!!
TOWRIGG
TOWRIGG
BX. NEW YORK
If they have their own manual switch to turn them on, then I'd get them in Canbus, otherwise the others only turn on with the interior lights and you will never have the dimming problem with them!! Just make sure that bulb will fit in the lights you are talking about before assuming that they will fit![/QUO
im gonna get them canbus too...makes sense since they have there own switch...weird how the same year trucks can react differently. i believe 03 and up some simple things changed like no under hood light or foot well lights but pre 03 has them...guess gm got alittle cheap..lol..
once again thank you for the info...well def let you know how it came out.
Rivieraracing
No problem, like I said a bunch of us spent months throwing ideas back and forth trying to solve this problem, the after a few fixes then someone mentioned that there was even such a thing as a canbus (I'd never heard of one before but the LED's were a new thing for me). That guy, 05nali, bought a few to try and low and behold it worked!!
So like I said, canbus style for any lights that you can turn on individually, and the rest you can use reg LED for as they only turn on with the doors open or manually turning all the int lights on with switch on the headlight switch cluster!!
Please do update this thread when you get them all installed please!!
SC88
Chicago Burbs
What style are you guys using for the puddle lights? I have the normal type and they don't seem as bright so I ordered a few canbus style to complete the interior and try for the puddle lamps.
Rivieraracing
I'm using standard LED bulbs for the puddles and they seem to work fine!! Shouldn't need Canbus ones for the puddles, but if you try them and they seem to work, let us know!
SC88
Chicago Burbs
Will do! I know I switched to the canbus for my front maps and beside being bright even with the key off there just overall a brighter light so i am hoping they will do the same for the rest of the lights.
Rivieraracing
Just make sure the LED bulb will fit in the puddle location, theres not as much space as there is in the dome lights!!
TOWRIGG
TOWRIGG
BX. NEW YORK
i was thinking the same thing about puddle's....canbus or not...def let us know if theres a difference..
TOWRIGG
TOWRIGG
BX. NEW YORK
THANK YOU!!!! they worked great...just ordered the canbus festoon ones for my second and third row maps.....
Rivieraracing
Nice man, glad to hear another happy result of using the canbus!! If you use your vanity lights (the ones in the visors) very often and don't want them to come on dim, then you will want canbus ones for them as well!! I didn't care so I left the regular LED's in there and when I use then I turn on one of the maplights with the canbus and they go full bright!
jESse
i like cheese
michigan
i love randomly coming across answers for stuff i wondered about but didn't ask. lol. i just swapped to led's last weekend and was lost on the dim thing too.
TOWRIGG
TOWRIGG
BX. NEW YORK
lol @ JESse....i love this sight...just when you think youre stuck on something.....boom somebody else has been through it and solved it...
Rivieraracing hit it right on the head with the canbus led's solution....and to think for $3 it solved a problem that wouldve drove me nuts...especially after spending $125 on the entire interior and finding out i have an issue...
---------- Post added at 11:09 PM ---------- Previous post was at 11:07 PM ----------
i do wanna do the vanity lights just havent messed with them yet to see what bulb they are...or how to get at them...
Rivieraracing
I can't take the credit for the canbus idea, that was 05nali's idea when we were trying to figure out it all!! If you want an interesting read, check this thread out!! It will show you the ideas and fixes we came up with to solve this problem!! Talk about a train wreck!! lol
http://www.tahoeyukonforum.com/forum/showthread.php?t=34369&page=22
Hodmjstone
