Fuel Pressure
Phone Man
Long Island NY
Okay this may sound stupid but I just checked my fuel pressure with an actron guage and it bounces really crazy between 50-55 PSI. I have never seen a gauge vibrate between readings that much. Is that normal for a Vortec or is my fuel pump going.
Key on PSI 60, key off PSI 45, barely any bleed down and holds for a while.
Thanks Guys
farwek
Lake Jackson, TX
Not the fuel gauge, pressure testing in the rail.
IMO, if it is still running good I would just leave it because those fuel tanks are a B&%^$ to drop.
But, the pressures that you recorded are about right. The bouncing of the pressure between 50-55 is normal, or at least my truck has always been that way and I have never had problems with pressure. Only problem I ever had was wire harness above the pump melted on me because the mechanic I paid to put a new one in after I had gotten some bad gas and ruined it, didn't use any type of connectors to keep the wires from shorting out.
Phone Man
Phone Man
Long Island NY
Ok thanks. Actually have P0300 issues up the ass and im taking shots in the dark now.
Korbin_A
