jdpber
GOLD MEMBER
The America
Vaccumed interior.. cleaned glass. cleaned dash... torqued all the lugs, checked all the tire pressures INCLUDING the spare.. which had 10# in it... all ready for the road trip
ajaxnxs
Rockwall,TX
wow i had a co worker who we had to go and get yesterday because her "HYBRID" NO GO !!!
nope....prius (because its a TOYOTA it is bulletproof) is driven by wifey....my Acura Legend has a slight coolant leak...and I replaced the head gaskets and whole top end 30k ago..not looking to do it again
I'm not super familiar with Acura's but is that a common issue? Have you tracked down where the coolant is coming from this time to know for sure it's not something as simple as a hose or something? I have to say I've always thought those early Legends were nice looking cars. I like the body style.
jdpber
GOLD MEMBER
The America
cood be your water pump crapped out.. you know that is the indicator that the pumps are going is that the leak FYI
CEN2MENTAL95
Banned
Expensive Long Island, NY
having my buddy take a look at it all....I replaced all 22 (yes TWENTY TWO) coolant hoses
with OEM 30k miles ago..... :(
and thanks...she is a looker even at 17 yrs old (zero rust and shiny white paint helps ;) )
replaced that too with OEM 30k ago...I did a complete coolant overhaul 30k ago along with the entire top end rebuild (including fresh OEM head gaskets and acura blue coolant)
22 coolant hoses???? Holy Guacamole!! :eek:
domin8
Just Plinking
Highland Park, IL. Transplant from SLC, UT to redu
Started the day off by ordering the GM Brush Guard light kit (17802903) and tow/haul mirrors package with turn signals and power folding (19243900), and a few other goodies. Then went to a customers shop and happened to be there when a tow truck got stuck in the mud in their back lot. They didn't have anything to pull it out, so pulled around it and went through the same hole in 2wd and had no trouble (Nitto Terra Grappler ftw). I was then strapped to the truck and pulled it out of the mud hole. People at the shop were impressed with the tires. Then, engine oil consumption issue reared its ugly head. That makes 1 qt in 2200 miles. I even tried using Lucas Oil Stabilizer. Next oil change I will try Valvoline Max Life and see how that goes.
Rivieraracing
Just finally got my O2 sensor from the UPS guy, now trying to get the computer to reset the code and turn off the check engine light!! lol If I can't get the light to go out by unhooking the battery, guess I will have to take it to the auto parts store to see if they will clear it for me!!
Alex33
Picked up a pair of 17" GM alloys for spares and my parts got delivered. Fuel pump, egr valve, cabin filters and fan clutch all waiting on me to do work.
Keipherlc
Maryland
Oil change, rear brakes, and IPC all done. Was happy until the Service Tire Monitor popped up on the info screen. :(
CEN2MENTAL95
Banned
Started the day off by ordering the GM Brush Guard light kit (17802903) and tow/haul mirrors package with turn signals and power folding (19243900), and a few other goodies. Then went to a customers shop and happened to be there when a tow truck got stuck in the mud in their back lot. They didn't have anything to pull it out, so pulled around it and went through the same hole in 2wd and had no trouble (Nitto Terra Grappler ftw). I was then strapped to the truck and pulled it out of the mud hole. People at the shop were impressed with the tires. Then, engine oil consumption issue rated its ugly head. That makes 1 qt in 2200 miles. I even tried using Lucas Oil Stabilizer. Next oil change I will try Valvoline Max Life and see how that goes.
how many miles do you have that you're burning oil on an 07? My 01 has 130k and doesn't burn any....
CHOO CHOO
BackPagePhil
Manheim, Pa
Pressure washer her yesterday and gonna try to give her a good cleaning today if i get the chance.
Sent from my DROID4 using Tapatalk 2
CEN2MENTAL95
Banned
85k
I'm going to try seafoam today to see if that'll help clean her up a little bit.
kinda low to be burning oil ???
seafoam will necessite changing the spark plugs and oil right after and that wont help oil burninng...
I would try 5 qts of Shell Rotella 5w30...that usually fixes any oil issue
great oil!
My 07 uses a little oil as well at the rate of ~1 qt per 3k miles. From my understanding this rate of consumption is "normal" or at least not big enough to warrant the expense it'd take to fix it at this point.
What oil weight do you use domin8? 5w-30? 10w-30?
Merch619
