Fog light mod
withac
Eastern Idaho
I don't see this anywhere yet and a lot of you have probably aready seen and or done this, but since we're all getting a new start here I thought it wouldn't hurt to start posting a few of these.
Okay, I did this to my 2000 ‘** and it worked great. I’m not sure what years it will work with, I got the write up from JKmotorsports, thanks JK. I got it when I was hanging out at that other Tahoe forum. I’ve changed it very little. It’s a real quick, real easy mod.
Here is what you do. Your fogs will be on when ever your parking lights are on. You go behind the headlight switch and jumper a wire from the switch over to the parking light wire. Simple as that. Its just you have no control over them now and they will be on when ever your orange lights are on. But that means they will be on with just low, or lows and highs. It will work it did it on my 02. (I guess this was JK’s comment, maybe somebody elses)
Remove the dash trim. I found this easiest to do if I slid out the ash tray so I could pry on the trim there, then worked my way around the bottom. Remove the headlight and fog light/rear wiper assemblies. If you look at the pics, there is a tab on the top and bottom of the fog switch. I’m pretty sure it was on the top of the headlight assembly as well. Slide something thin in between the assembly and the trim it’s mounted in and it’s pretty easy to gently disengage the tabs.
I assume all rides are wired the same but I’d test the wires first to be sure. You don’t need a volt meter, just a simple circuit tester will work, I’ve included a pic of what I used. Behind the parking/headlight switch test the wires for power when you turn the parking lights on. It is the light blue wire on my ride. Others have power constantly but you want the one that turns on and off with the parking lights. Behind the fog light switch check the orange, black, and purple wires. You want the wire that turns on and off when you push the fog light button. Mine is purple. Now use a piece of 14-18 gauge wire and a couple of in-line wire taps to jumper the two wires. This should get your fogs to come on with the parking lights and stay on when you switch to high beams.
HMFDZ28
Hunt Sta, NY
Not a fan of the blue quick taps (they tend to heat up and fail) but sounds like a cool mod
BOSS
The People's A D M I N
Dallas
Excellent write up...keep em coming bro!
BOSS
withac
withac
Eastern Idaho
Thanks guys. I heard complaints about the T-taps coming loose before but not the blue in-line ones. I wouldn't have thought there would be that much draw there but then I don't know Jack about electrical systems.
BOSS
Dallas
Since I have no electrical knowledge WHAT-soever, I've got my work cut out for me, I'm doing a mod that, as far as I know, has never been done the way I'm attempting. I know it can be done, it's just a matter of my dumbass figuring it out...now I know who I can hit up for help ;-)
BOSS
HMFDZ28
Hunt Sta, NY
The Blue ones arent too bad but I have seen them fail. Most failures I have seen are when they are used in grills and exterior in general. People try and take the easy route when installing grill LEDS and then well I gotta go fix it lol. If I seen them in a chiefs truck or pd car my company requires me to fix it lol.
withac
withac
Eastern Idaho
My logic is that for inside the dash like they are I'll be okay. Hope I'm right. I did the 4-hi mod so my high beams stay on with my lows. I used the blue taps just to make sure I had things wired right then when I knew I had it I took them off and cut the wires and spliced them using crimp connectors. I need to go elevate my knee (ACL surgery last Wed) but some time when I have more time I'll write that one up with some pics too. That one is well worth it. I've also got an instrument cluster light change over (gives you a different color) write up in the wings. I came up with none of these myself, just got them from guys who know more than I do. But they work and are easy so when I get around to it I'll post up. That is unless someone beats me to the punch.
HMFDZ28
Hunt Sta, NY
I can deff see your logic... and for temping to see if it will even work the way ya want lol. I love seeing and reading write ups. It just shows how creative people can be. Keep up the great work man!! BTW feel better bro... ACL surgury has got to suck! I had three surguries on my ankle to put it back together and that blew!
vatahoelt
NoVa
I did a little different set up for my tahoe. I actually wired my existing fogs to run while my DRLs on. I then installed an aftermarket set of fogs on my Westin Bull Bar, which I control with the factory fog light switch. No extra relays or anything were needed. Just cut the wires from the back of the fogs and spliced into the DRLs wires. Then ran new wire from the existing fog light wiring to the new fogs. Took about 45 mins total.
TheFuzz
Idiot Police
Spurbury, VT
Now THAT is a cool idea. I'm getting a Go Rhino push bumper eventually, and I was planning on mounting some PIAAs on it. Not sure if I want the fogs only on w/ the DRLs, so I might just splice the PIAAs into the existing fog lamp wiring. Not sure how exactly I want to set it up yet...but I like the idea of not have 47 switches in my dash for accessory lighting. I'm all about clean.
vatahoelt
NoVa
i agree. plus trying to run all those wires and stuff everywhere can get hectic.
because really, the stock fogs don't really do much and if you notice at night they bounce around quite a bit. i had also just spent $35 replacing one that had gotten stolen. so i didn't want them just sitting there. so this way they at least get used and it makes me a little bit more visible on the road with all the crazies out there.
TheFuzz
Idiot Police
Spurbury, VT
Yeah, I gotta replace one of mine too, the bulb in it was blown when I bought the truck. And when I say blown, I mean the thing physically exploded. The housing is completely destroyed inside. I have yet to determined what caused it since it happened before I owned the truck.
I think I'm just gonna replace everything in one shot since all of the lenses are so worn. I'll do the grille shell, turn signal lenses, fog lamps and Denali headlights all at the same time. Should breathe a little life back into the front end.
Mr45
Florida
You'll like that Go Rhino....I love mine....
TheFuzz
Idiot Police
Spurbury, VT
Good to hear. It's on the wish list, but I have my LQ4 sitting in a crate which still needs a cam and some other goodies before I drop it in...plus I need to beef up my trans. Gotta prioritize my cash. If I can score a used one for cheap and have it re-powdercoated or something, I'd do it. But they are a rare find on craigslist.
bub
jersey
nice write up but i was curious about something. so the fog light button has no function anymore and you won't be able to turn them off if you wanted?
97transam
Always been annoyed that I had to constantly remember to push the fog lamp button on. Thanks for the write up for this easy mod/fix.
dizhai
