How do I remove the Tahoe rear applique above tag?
DwDrummer
AL
Looking to replace mine and was wondering if anybody had any tutorials on how to do this? Is it hard to do? Thanks, DW!:Handshake:
KMeloney
D - I don't know how to do it, but apparently it IS hard to do. So, not sure if this is your best route to go, but... I'm sure someone else will chime in.
Modded
That Guy
Good luck DW. Don't even attempt it unless you are real mechanically inclined. Just take it to a body shop. Most body shop damage the old one while getting it off because it is that hard. Good body shops won't though.
domin8
Just Plinking
Highland Park, IL. Transplant from SLC, UT to redu
It's not that hard. One day I was juggling too many things while trying to get into the back of my truck and accidentally popped it off. I thought I had broke it and would need to buy a new one. I was able to snap it right back on. I'll see if I can get some pics and explain it later.
Sent from my myTouch_4G_Slide using Tapatalk
Modded
That Guy
Connor you probably did break it a little. Every body shop I have asked about it (about 4 GM body shops) agreed that they would probably break it while removing it.
The only way to get it off is by removing the interior panel and going to town with four spinning screws. It does not pop off unless it was never installed properly.
randuff
DFW
I work at a Chevy dealer and my body shop said it is necessary to heat it up because of some kind of nut thingy (I am obviously not mechanical) to loosen up otherwise you will break the clips and nut.
InTruckDesign
SW CT,
I took the one off my tahoe and had it shaved when I first got it. You need to remove the interior plastics, then iirc remove the mounting screws for the wiper motor, slide the motor to the side to access 3 or 4 hex heads. Then remove ir slowly from the outside so you can disconnect the rearview camera and license plate bulb wiring. It should not take more than 30-45min. start to finish.
DwDrummer
DwDrummer
AL
Thanks will the nuts and clips come out of the old applique and mount in the new one? The one I'm looking to buy doesn't have them.
Is it necessary to remove the wiper motor to access the bolts? Thanks for all the help everybody!
domin8
Just Plinking
Hmm, looks like I have something to investigate.
IMO, it'd be MUCH easier to removed the rear bowtie, this the holes and paint.
GalaxyBlackEsky
BlackedoutLT3
MD
Damn it is a big pain in the ass! I am trying to mess with mine right now. I have the Yukon appliq on it already just my freaking license plate bulb plug blew and I need to replace it and took off the interior plastic and the nuts and screw just keep spinning for the appliq.. I might just say screw it but my OCD keeps bugging me about only one tail light bulb working.
tonester1011
nj
It is a pain in the butt but doable without breaking anything. At least I was able to. Getting to one of the nuts is a ***** andeven harder to get it back on without removing the wiper stuff. Just take your time. Should be good.
DwDrummer
DwDrummer
AL
Will the bolts and white clips out of my Tahoe applique come out and fit into the Yukon applique? Most all the ones I see for sale don't have any bolts or white clips.
RickyFriery97
anyone know where to order a new on of these? mines broke and really lose, even a black yukon one will work, cant find one anywhere though. ill agree on it being a pain though thats for sure!
DwDrummer
DwDrummer
AL
I've got a Escalade appliqure I'll sell you and I've already got the bolts glued in.
NathanJax
Vacation Nathan
Jax, Fl
Pics? is it black?
http://www.tahoeyukonforum.com/forum/showthread.php?t=38410
CKendrick
