Navigation swap!?
steven13608
I have an 08 tahoe LT3 with the navi and i was wondering if i could go buy, lets say, 2012 tahoe/yukon stock nav. Could i install an 12 navi in my 08 truck with no problem? Anyone do this before?
thirsty1258
What's new about them ? Don't the aftermarket ones look just as good and function well for cheaper
Sent from my Galaxy Nexus using Tapatalk 2
NathanJax
Vacation Nathan
Jax, Fl
No you can't. 2012 was all new wiring and plugs. Already been brought up.
http://tahoeyukonforum.com/forum/showthread.php?t=37085
2012
2011 and older
steven13608
steven13608
But a 11 and an 08 are the same rite? Is the inter face anydifferent? Would there be any benifit of going to an 2011 from a 08?
NathanJax
Vacation Nathan
Jax, Fl
But a 11 and an 08 are the same rite? Is the inter face any different? Would there be any benefit of going to an 2011 from a 08?
08-11 are the same wiring. Couple differences like USB input and different mapping
AaronIROCZ
Tomball Tx
Actually yes you can, I believe I was the one who said that it was not possible and I was wrong. I have a 2012 Silverado without nav and that basically gives you 2011 and older plugs to the non nav radio. I had Greg at CPS Audio Video in cali sell me the Nav unit, and wiring harnesses of which comes preprogrammed for your truck so essentially it is plug in play from them and the whole setup costs 1500.00. I also opted for a video harness and that was an additional 50.00. This unit is quite a bit different from the 2011 and older units, completely different look to the software. It also has it's own XM tuner built inside it as well. Sorry for the crappy pictures lens was dirty.
NathanJax
Vacation Nathan
Jax, Fl
Yup. I was just going off your info. Glad to see you got it worked out.
felixgun
Lafayette, LA
does your navi have blutooth?
Bluetooth is in the vcim unit which is a module behind the dash also tied to OnStar. If you have a GMT900 vehicle that is 07-08, you can purchase an 09+ (when BT came out) and switch yours out and Bluetooth will work.
GalaxyBlackEsky
BlackedoutLT3
MD
Is that really the 2012 headunit????? I Have never seen pics of that
---------- Post added at 08:56 AM ---------- Previous post was at 08:49 AM ----------
Wow ok I just looked it up and it is. So this might be the next mod.
yates ™
Resident Apple hater
Iowa
You do realize that you just explained the exact opposite of what the OP is wanting to do.
AaronIROCZ
Tomball Tx
No I didn't your missing the rest of my reply in your quote, The wiring didn't change for all of the 2012 fullsize SUV's and Trucks. The wiring changed for ONLY the trucks and SUV's with the factory installed Navigation unit. If the truck was not ordered with Navigation from the factory the wiring plugs are the same from 07 and up. Just clearing up the misinformation I was given when I first looked into this and was told I couldn't do this. SO Yes this 2012 GM OEM Navigation unit will work in all 2007+ NNBS fullsize trucks and SUV's with the proper adapter harness from what I have been told by Greg at CPS audio and video. And heck for that matter you could install the 2011 and older Navigation units into a 2012 if so desired and no adaptors would be needed.
dizhai
