2007 Suburban LT
edgaranah1
Corona California
Nice. Like the color.
And about the service airbag Jacob is probably right I had that message and tracked it down to a disconnected plug under the passengers seat.
soulsea
Bar
lol Jacob, drl easy to change?
If spending 1/2 hour taking bumpers on and off is easy then I agree. :)
felixgun
Lafayette, LA
Make sure when taking off the headlight you remove the wheel well cover to remove the bolt underneath the headlight so that doesn't snap off when trying to change out your DRL. Also if you see the V4 to V8 change you definitely have AFM.
edgaranah1
Corona California
More like 15 minutes tops if you have never taken the bumper cover off. I learned pretty quick when I had my Cheap O HID kit.
THE YETI
Director of Operations
South FL
15 minutes? good lord... takes me about 30 minimum. I cant rush that stuff, too worried about scratching the bumper or something stupid.
soulsea
Bar
Yup, the very first time I just rushed to pull out my Tahoe tail light I gashed the top of my bumper ... three lessons leaned 1. Always put a rag tween the light and the bumper when taking tails out, 2. Once the clear coat scuffs it looks like ten kinds of ass, 3. NEVER RUSH
My original point was he could do it himself and it's not rocket science. :Handshake: not worth paying someone to do for him
domin8
Just Plinking
Highland Park, IL. Transplant from SLC, UT to redu
Yes, pulling the front bumper is very easy. Just don't forget to unplug the fog lights. And, 15-30 minutes seems about right.
As for the airbag issue, worst case scenario is a failed sensor in the seat. It's very easy to replace, but the part can be a little pricey. You can install it yourself in less than 1 hour, but it'll probably need to be programmed by the dealer. If you want more info please send me a PM as the pisa are good that I may miss any reply to this post. I just did a similar job for my neighbor on her 07 Equinox. If your fix is anything like hers, your won't need anything more than a basic socket set.
JochenWoern
JochenWoern
Sacramento, CA
1. Daytime running lights are easy to change. I need to the same on mine.
2. Yes it appears yours has the fuel management system. Not sure if they all have it in 07 or not.
The airbag message is most likely one of the sensors unplugged. Mine currently has the same message. I just have not taken the time to track down where it's unplugged at. Most likely on the console side of the passenger seat cuz the wife likes putting stuff down there like umbrellas and stuff.
Thanks very much Jacob.
1. I changed the Daytime Running Light this evening after work. It was pretty simple, but the NBS Truck is way easier.
2. Cool, I assume this will help with the gas mileage.
I wonder if the Airbag Issue happened when the dash was replaced?
---------- Post added at 12:00 AM ---------- Previous post was Yesterday at 11:58 PM ----------
Thanks very much.
I will definitely check that out in regards to the plug for the airbag.
---------- Post added at 12:02 AM ---------- Previous post was at 12:00 AM ----------
Did not have to take the bumper off.
---------- Post added at 12:11 AM ---------- Previous post was at 12:02 AM ----------
It did not appear that there was a bolt on the bottom. I simply took two bolts on the top off and then I moved the headlight assembly outwards and released the two plastic pins that align the headlight to the fender. I just got enough room in order to get my hand down there in order to exchange the bulb.
I knew you could do it JW :waytogo: Serge is just a doubter :lol: how long did it take you to fix the drl?
soulsea
Bar
Well that's probably why you didn't have to take the bumper off ... either the bottom tab is broken, or the previous owner had the foresight to leave it unscrewed. Otherwise getting to that bottom tab is what takes most of the time and effort.
JochenWoern
JochenWoern
Sacramento, CA
I wanna say it took me about 20 Minutes PLUS an additional 5 Minutes to cuss out GM Engineering based on my NBS experiences.
SERGE: Are we sure that there is a bottom tab on the 2007 Truck, as I checked the other side and it as well seems to have "some play" when I push on the bottom? (It does not appear to be mounted as "solid" as the top portion of the light assembly).
If the previous owner left the bottom tab off, then have to say WELL DONE! After mounting the headlight assembly back in its place, I would have to say that there is NO NEED at all for a screw on the bottom. The two (2) pins/plastic studs going into the fender PLUS the two (2) mounting screws on the top seem to be plenty to be holding that Light in place??????!!!!!!!
---------- Post added at 11:07 AM ---------- Previous post was at 10:58 AM ----------
Off-loaded this afternoon at 1:00 PM in Cali.
Overall, I am very happy with the vehicle, no dings, dents or scratches. Interior looks clean and all seems to be working with the following exceptions (which I am NOT very happy about and I have already contacted Texas Direct Auto, we shall see what their reply will be):
-----> The Rear Bumper Cover for the Spare Lock is NOT INSTALLED as it was agreed.
-----> One of the front Daylight Running Bulbs is out and NOT WORKING (minor).
-----> The moment I started the truck the "SERVICE AIRBAG" Light comes on and the DIC (Driver Information Center) Display also states this issue (MAJOR)!!!!!!!!!
She drives nice and shifts as it should, no vibration or any alignment issues. This weekend she will receive a Major DEATILING job as well as the Door Debading.
So, NOW the QUESTIONS will begin:
- On the NBS truck changing the Daylight Running Bulb is a breeze. Can I do it myself with the NNBS truck, or is it a major pain?
- If my DIC shows me the Fuel Economy between 8 cyl. and 4 cyl., would my assumption be correct that the vehicle therefore does come with the Active Fuel Management System? (Did all NNBS Trucks come with that or is that an extra feature?
Thanks in advance guys.
Got word back from Texas Auto Direct stating the following:
"Mr. Woern,
Thanks for the email. I was out of pocket yesterday and regret the late return of your correspondence. I will ship you the bulb, and lock cover.
After I had noted the cover in our system, it was closed as completed. I am sorry that I was not able to put my hands on her again to verify.
I have my service manager notified of the situation with the service airbag light on. I did not see this notification when I was able to look over the truck. She will contact you as to how we can go about making this right for you. You should get some sort of communication from her today. I have placed your email on her desk.
Again I apologize that these issues slipped through our fingers, we endeavor to do a much better job than this. I look forward to hearing from you. I hope this finds you and yours doing well."
Seems like they are willing to take care of the issues for me and that's all anyone can really ask for. Mistakes will happen, as long as they are corrected all is good.
I've always heard very good things about them!! I'm glad to see that they do seem to be a reputable dealer! :waytogo: It's awesome that they genuinely appear to be working on making everything as easy and as painless as possible for you.
JochenWoern
JochenWoern
Sacramento, CA
Was contacted by Texas Direct Auto this morning, letting me know to take the BURB to a dealer, have the airbag issue diagnosed and send them an estimate for the repair and they will cover it.
So far so good. :)
OHSIXX
Milwaukee
Good to hear.......now you will be the new expert on all things GM since you have a NBS and NNBS :D
felixgun
Lafayette, LA
Yea Jochen the bottom screw on the headlight is totally unnecessary but it is definitely there. It definitely was broken off if the headlight came loose with just the top two unbolted.
JochenWoern
JochenWoern
Sacramento, CA
Thanks Felix. The headlight seems to be secured properly so I am not going to worry about it.
Took her to the local CHEVROLET Dealer this morning, after having the VIN # verified at the CA DMV.
- Getting an oil change and possible tranny fluid change (if needed) and I will also have her checked out in regards to the shocks as well as other issues.
When she comes back, she should be all good to go for the Mrs. to be happy.
JochenWoern
JochenWoern
Sacramento, CA
So far so good. :)
So, here is the latest update in regards to the BURB as well as Texas Direct Auto (TDA). NOT HAPPY WITH TDA ANYMORE!!!!!!!!!!
As mentioned before, I had an Airbag Light come on as well as a Power Seat that does not go down all the way. TDA said they would cover that cost. Now they say they will only $65.00/hr. in labor and they would not pay any taxes. Now where in California they think I can find a GM Dealer with a labor rate of $65.00 is beyond me, but that is all they will pay. My dealer charges $113.00/hr.
As I had mentioned before, I had some issues with rattles and squeaks, also had to replace one of the Daylight Running Lamps as previously mentioned also replaced BOTH rear licesnse plate bulbs.
I wrote some of those, as well as new issues down for the local GM Dealer to troubleshoot:
- some loud rattle noise when hitting rough surfaces on the road or any bumps.
- a constant squeak in the wheel area, which I personally diagnosed as a possible wheel bearing or brake issue.
- Furthermore there has been a squeal/squeak in the engine bay as well.
- the check engine light came on in the meantime.
- Door cylinder lock not working.
Took the BURB to the local Chevrolet dealership in order to address these issues and here is the verdict:
- Rattle noise front end -- front sway bar links need to be replaced
- Squeal noise engine area -- needs Ac and serp belt
- Brake Squeal -- needs front brakes
- Check engine light -- needs evap purge solenoid
- Door Cylinder Lock broke -- needs replacement.
I am not very happy with TDA, as they did ship a vehicle that had issues and they did not advertise these issues at all. I specifically asked them on the phone if the vehicle needed any attention, they clearly stated NO!
Furthermore, I believe that the vehicle was NOT accurately described/advertised in their listing based on the above issues. ANYONE driving this vehicle should have noticed these issues and should have either corrected them or should have advised me accordingly. NEITHER TOOK PLACE!
The vehicle was also advertised with the Factory Entertainment System (DVD Player). Part of this system is the remote control as well as TWO (2) Headphones that come standard from the factory. These items were missing and they were NOT advertised as missing in the listing. This as well I purchased at my own cost.
The rear bumper cover supposedly was installed and verified to be on the truck, the vehicle shows up without it and no one knows what happened????
Issues that should have been addressed prior to shipping the vehicle, I now need to take care of my self and on top of it all, TDA will only cover $65.00 for the labor of something that will cost my $113.00 at the local dealership. Not only am I taking care of issues that should have been taken care of by TDA, they are also restricting my abilities to have it taken care of by them only covering half of the labor cost.
I will say that TDA was ON THE BALL trying to sell me the vehicle, ever since they got my down payment and have taken care of my financing and have gotten their moeny, progress is very slow at best.
My advise, if you by a vehicle from TDA, DO NOT DO IT SIGHT UNSEEN.
The above issues will cost me now $1,600.00 (including a tranny fluid flush, oil change and power steering fluid flush) which should have been taken care of OR AT LEAST MENTIONED by TDA.
Oh, and I have received FOUR (4) new Interior Chrome Door handles based on the extended GM Warranty on this rig.
Thanks.
However, the dealer states that once all this work is completed, THE VEHICLE WILL BE IN PRISTINE CONDITION.
Candielaine
