Wiper motor question
bowtiefreak
No Quarter
Near Philly
I need a little help. My wipers didn't work today when the rain started. I hit the motor and they started, conclusion is the motor is bad. I quick looked in LMC to find one, $100 isn't horrible but I'll look around
My question is this: Do I need the unit with or without the delay? I have intermittant wipers, is that what the delay is?
domin8
Just Plinking
Highland Park, IL. Transplant from SLC, UT to redu
Front or rear motor?
I'm assuming it's the front wipers that are your problem. I have an A1 Cardone number of 40-158 for reman and 85-158 for new. World Power Solutions is WPM158. Dorman/OES is 601-101 (discontinued, but showing one in warehouse). I hope this helps.
Tbruz
Windham NH
Might not be the wiper motor but rather the circuit board controlling the wiper motor.
This was a known issue that caused a recall by GM when wiper motors were stopping.
If it is this board, you can get one for like $25 from Amazon.
P/n for my 1997 2 door is 19254082
Easy to R&R too!
PM me your addy and I'll send you the spare one I have to test out.
Tbruz
bowtiefreak
bowtiefreak
No Quarter
Near Philly
front wipers in the culprit. Looks like some come with e new circuit board. Like I said I could hit it and it would work. So Napa has them rather cheap. I may just pull it out and go get one.
Tony, I may take you up on that. Thanks for the offer.
gpracer1
Phoenix
Pull the circuit board out ( after pulling cover) and resolder the big pins. 99% of the time problem solved........both of my hoes.
bowtiefreak
bowtiefreak
No Quarter
Near Philly
good to know, the crappy part is it's working again now so it's tough to find the issue.
Tony, I may be in touch sooner rather than later :)
ChrisAU
Birmingham, AL
Mine were like that too...it was the circuit board, and its very common. Cheap part too.
fishmagnet
Had to replace the circuit board on my '98 also. Sometimes the wipers would work, sometimes they wouldn't. Now they work 100% of the time.
bowtiefreak
bowtiefreak
No Quarter
Near Philly
cool, thanks. The motor sounds weak and doesn't seem to pull the wipers down as low as they used too. The board is controlling the motor though right? Like a VFD on an AC motor? So if the board goes bad the motor loses power?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
I would not describe it that way but yes board controls motor.
bowtiefreak
bowtiefreak
No Quarter
Near Philly
I work with a lot of AC industrial motors, it's how I relate things
Or is this more like the resistor on teh HVAC controls?
gpracer1
Phoenix
The solder joints at the power connector crack and make an intermittent contact. That's why sometimes they work, stop halfway, don't work, at random.
I should have done a write up with pics when I did mine, but I'm traveling to Canada 95% of the time now for work, so no more time to help out here.
WalterMitty
Oklahoma
Easy to R&R too!
Tbruz
This is what happened to my 95. I paid to fix it then got a rebate from GM.
Yizzo88
