Complete Lighting/LED List
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Unscrew for screws holding the assembly, carefully remove module and you will find the bulb socket on the back. Turn them slightly and pull out.
98chubby
I'm sorry about that i was reading the wrong part i'm an idiot! yes me!lol. It's 1157 that i really meant. My question is do the leds from superbrightlights come with the dual for the blinker and running lights? Also do i need any resisitors? thanks
SunlitComet
OBS Jedi-Do Good
1157 are dual circuit. You will either need load resistors or a led compatible flasher for the turn/hazard signal circuit. Each one will be a separate cost. Go with a flasher unit you only need one for the whole system and not multiple resistors which just take up space. My specific setup had resistors already installed front and back. With the flasher replacement I cut and removed them all for a true "energy efficient" conversion. The flasher for should be good for turn and hazard.
the big blue bus
richmond, va
what mm dome lights are yall using? the last time i ordered some they were too long 42mm i think. i measured the bulb and its like 38 mm i think. got some hp white leds off ebay the are sick. 10 for 10 bucks lol bright as crap got em in doors under dash and dome lights. got 10 blue comming as well for guages. started with the single led blue then the 5 now hp5 hope they do the trick
BamaDogg
What style is everyone using in their floor shifted, glove box, map lights, etc. All are 194's. What about dome lights?
99boxhead
cin,oh
wanna order my leds today. I got a question tho, can you change the needle color?
99boxhead
cin,oh
got em in
xanatost
Lafayette, La.
If you do the led upgrade will you louse the dimming ability? I want to go blue but I don't want to be blinded by them. I was looking at supper LEDs site.
KPOD
Michigan
Indicators(instrument panel): T1.5s - 16 total, but will vary depending on how many indicators you have operational.
Can anyone tell me what exactly he is referring to? I know it's not the dash gauges. It appears you need 4x bulbs for the HVAC, so I'm not sure what's left after that? A picture would be excellent :hands:
Phil S.
Wheaton Illinois
I am going to post in the wanted section too but I was wondering if anyone had a working map light housing they would sell to me? My kids were horsing around in the back seat and must have worked it loose, I found it on the floor but now I am pissed as I thought it was a bulb from another project I had completed and I threw it away. I never looked up to see the empty socket!
kaoticlife
Port St Lucie, Florida
Yes with leds you will lose your dimmer function, but I have blue leds in mine and it isn't too bright at all!
Sent from my SPH-D710 using Tapatalk 2
haks310
haks310
Got LEDs?
SoCal
The 95s have a different AC/heater control panel than the 96+ models. On the 95s I believe they're soldered in or just a pain to replace. The 96+ units have the twist sockets and are easily replaced.
I have a 95 and I'm trying to come up with a harness to connect the two connections the 95s have to the three the 96+s have in the AC/heater control panel.
scottd
