Grounding car audio
ckl5899
San Antonio
Where did you guys ground your subs?
Did you run another line from your battery?
Did you ground to a bolt in the cargo area? If so where/which one?
NathanJax
Vacation Nathan
Jax, Fl
Haven't done mine yet... But ground it to a bolt going through the body. Then under the truck, use another wire to ground that same bolt to the frame.
That will give you a proper ground and the best ground possible.
RickyFriery97
Best ground possible is straight from the battery, not the frame.
OP if you have the wire, id run a extra run just for ground
veteran111
