Swap Hummer H2 Wheels for Stock Yukon XL
ARAMP1
Memphis, TN
I really don't like the stock wheels on my 2011 Yukon XL (the five spokes don't really mesh with the 8 lugs IMHO) and was thinking about swapping in just some stock H2 wheels when I need to get new tires. I'd probably have them powdercoated black.
Anyone know if it's a direct fit or of the backspacing is different?
soulsea
Bar
Well, other than the fact that your Yuk is 6 bolt and Hummer rims are 8, it's a direct fit. :)
Serge, according to the posted pic his Yukon is an 8 lug. 3/4 ton XL? :shrug:
soulsea
Bar
In which case disregard what I said ... and I don't just mean on this thread, I mean anything I've ever said.
Now to figure out if I'm too drunk or not drunk enough ...
Gzes
the drifting 2dr
Wichita tx
lol well its gm so yes it should fit. im getting h3 rims for my 2dr probably if i find a set cheap enough...
What's that shiny object in the corner?
InTruckDesign
SW CT,
yes H2 wheels are a direct fit to the 3/4=ton burbs. the tires=not so much.
Goodinblack
I Like Tacos
Dirty South
Now to figure out if I'm too drunk or not drunk enough ...[/QUOTE]
:Good or Bad:
I would rock those factory rims in a heartbeat, not on a truck but a 15 passenger van....
ARAMP1
ARAMP1
Memphis, TN
What size are the tires?
I was planning on going with at least a 285/75-17 in a radial super swamped/interco but ill probably have to lift the front at least level with the back.
---------- Post added at 01:14 PM ---------- Previous post was at 01:10 PM ----------
3/4 ton XL? :shrug:
Yes, its a 3/4 ton 4 wheel drive.
Blakesan
NH
make sure u post some pics id love to see h2 wheels on a xl
ARAMP1
ARAMP1
Memphis, TN
Nothing yet. I'm probably going to wear the stock tires down first before I get serious about scouring craigslist for H2 rims.
Gzes
the drifting 2dr
Wichita tx
I bought h3 rims for $150:) they are like new just been slacking off to get em installed
SMiller
I also have a 3/4ton and was thinking of installing some H2 wheels, I think 285 or even 305's would fit and barley rub on full lock on H2's.
Would love to see a picture of this setup!
I think I am going to see what 285's look like on the same stock wheels you have first before making the wheel swap. The H2 polished/machined wheels would look great though!
Tons of '07-'10 2500 GM trucks running this setup, same frame and suspension clearance and other then a rub at fill lock no problems, you will have to crank the bars all the way but that isn't saying much as turned up all the way is only about 8-9 turns so not a lot of adjustment anyways.
H0llyw00d
I am looking into doing this with my '10 2500 xl. The main difference is the offset on the stockwheels is +29 and the h2 offset is +18.
Steamin
Wow. It looks great. What is even more impressive is you coming back after all these years and posting pics. That is next level!!
048tahoe
