SOB oil drain plug seezed
MASS-HOE'Z71
Mass
went out last night and grabbed all my qrts of royal purple and a shiny new k&n filter, go out nice n early this mornin and the drain plug wont budge and me thinks the dealership with their free oil changes used an impact wrench to put the plug back in,never had this happen on any other cars, its usually the filter thats a ***** to get off, but either way i spent a good 3 hrs trying to figure out how to get the thing off while tryin to be careful not to strip the fine threads on the pan or the plug itself, ive been goin out to periodically soak it in wd40 then give it a go with the giant torque wrench but nothins workin, last thing i wana do is replace the pan/ plug and i'd rather not pay a garage to do it for me,
Any suggestions?
Donkey Punch
Panantukan
Any suggestions?
put some muscle into it.... socket and a 1/2in rachet should break it.... push instead of pull, it'll be that much easier otherwise there isnt much you can do.
bwilly20
Carolinas (Orig.), Little Rock, AR (now)
i agree, one thing ive learned from workin on planes for the last 6 yrs is to loosen some things, you've gotta tighten em. put a little more torque on it to tighten it, that may break any corrosion or anything else not lettin it break loose, then try and loosen it. just my .02 .
Rivieraracing
True on the tighten a little before you loosen it theory, it works sometimes for me!!
Also, if you have a good fitting socket on the oil drain plug, use a breaker bar on the socket and smack it a few times with a mallet in the direction of loosening it while trying to loosen it, that works sometimes for me, just make sure you socket has a great grip on the bolts otherwise you will strip the bolt head.
TheFuzz
Idiot Police
Spurbury, VT
Left loosey, righty tightey.
:D
Sorry man, couldn't resist. I second what the rest of the guys have already suggested. Short of heating the damn thing (not something you really wanna do near the oil pan, lol), you just need to get some PB Blaster or Kroil on that ***** and get the biggest breaker bar you can muster to get it loose. WD40 works ok but I've had better luck with PB actually penetrating stuck bolts.
Anthony
2004 Tahoe LT (MA)
Westen MA
:D
WD40 sucks in the long-term it turns to basically glue after extended time/use
PB Blaster FTW!
MASS-HOE'Z71
MASS-HOE'Z71
Mass
yeah i eventually got it, took a few days cuz it was too hot to do after the commute home from work and ended up just gettin sum taller ramps from sumone and extended the wrench with a pipe and got it that way, then ended up buying a new drain plug cuz the old one was a lil stripped
+1
finally ordered my hids last night from ddm, just the lows for now to see if i get pulled over then probly do the fogs soon enough
WoldD90
Off Road Addict
Atlanta, GA
WD-40 is a water dryer... Try PB Blaster or Liquid Wrench. Soak it and let is sit for an hour or over night. Then you should have better luck.
mr. yuk
newport, nc
i would also suggest for further referance making sure you use a 6 point socket not a 12. you'll love your ddms. i know i sure do. what k did you get. i went with 6 but should have went lower maybe a 4.
MikeTheApeman
The armpit of America - New Joisey
It's funny, I thought of this very thread yesterday as I changed the oil in the hoe for the first time. Sumbich plug would not come out. Luckily the Mrs actually got me something for X-Mas that I asked for and finally got to use: cordless impact driver. :hands:
MASS-HOE'Z71
MASS-HOE'Z71
Mass
:Plugged:
Yeah upgraded all of my sockets to 6 point sockets for standard and metric, wasn't cheap but has already paid for itself in convenience and replacement bolts as I have a habit of stripping them....... I was gunna stick with 4300 or 6000 but got impulsive and went with 8000k then maybe do 6000 in the fogs, should be here Wednesday and my led interior domes should be here maybe Thursday or Friday
mr. yuk
newport, nc
:Plugged:
i also thought of getting a spare drain plug cause if im changing the oil and no one is home and i strip it, well you know.
ddm's prices are good and the product is awesome, you will be happy!
MonteJ
