Arnot shox...Getting higher?
pmexpert
Moscow, Russia
had installed new Arnott shox with autoride support to match OEM function. Found that front become almost 1" higher. Does anybody knows the reason?
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
DO NOT buy those. THEY DO NOt replace internals all they do is replace the air bag. the core section of the shock is untouched so all you are doing is buying a shock that has been repainted and might have 120k miles on it but new air bag on it.
pmexpert
pmexpert
Moscow, Russia
I checked everything with special stand that is used for suspension testing. Everything is absolutely fine with them. You are absolutely right, they taking the shox and puting an airbag. But shox are new and made by Bilstein. It's not OEM. I kept them a lot in my hands. Rods and bushing had not even a small wear... You can pull down upper part of airbag to see rods condition. Don't think they chromed rods to make them like new:) And front shocks are just made by Bilstein. I was really surprised by compressor supplied. It's really quite and makes its job very quick.
I can place photos here if you wish :)
By the way, new shox are not MagneRide
KMeloney
Did ONLY the front get higher? Did the rear stay exactly the same as before the replacement?
And did you only replace the front shocks?
pmexpert
pmexpert
Moscow, Russia
It seems that only front got higher. Now the distance from fender to tyre in the front and rear are almost the same. Previously rear was a bit higher than front. I replaced rear+front+compressor
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
snap ring area is set higher up on them so inturn truck sits higher.
pmexpert
pmexpert
Moscow, Russia
Likely you are right. OEMs spring seaters are lower. So Arnotts with ring is approx 1" higher... Thus it wasn't so easy to install. Need unplug upper ball-bearing to put them on place
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
pm me ill tell you how to fix it ive dealt with this before.
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
mine was the same way, thats why we opted to remove them and replace with the drop belltech ones
pita
no this is a $15 dollar mod ive been doing for years on local guys trucks who want to save money and lower up to 2 inches more on stock shocks.
Off Road Pedia
