best HID fog lambs for yukon
THE YETI
Director of Operations
South FL
i googled fog lamb and got this?
soulsea
Bar
C'mon people, be serial.
New Zealand fog Lamb is the best.
High
Intensity
Deliciousness
drroy
Not sure if its an issue for yukon. But 35w HIDs in the fogs of a tahoe leads to problems. I have heard of lens melting, i had a kit in my fogs that i turned on only a few times because the color was off and it scorched my reflector. I understand there are some 25w kits avilable.
THE YETI
South FL
Sam, its okay, we all knew what you meant, just breaking you in to the forum with some good ole' fashioned humor. :D
If you run HIDs in the fogs, run a 25w kit, do NOT run a 35w or 55w kit or your foglamps will indeed melt.
VisionxOrb
ive been running DDMtuning 4500k kit in our denali for a few months now with no melting ( knock on wood ) I read some where that they use a slightly shorter bulb for distance from the crap plastic lens ( it did look a little shorter than standard 900x type bulbs ) if that really makes a differance in melting I dont know
ROB'S-HOE
V leds sells a good pair of led bulbs. They are nice and bright and match the hid look, might want to look into them.
KMeloney
Whichever fog lambs ewe go with, I'd smoke them bla-a-a-a-a-a-a-ack.
badblu97
I went with leds in my fogs, I was told by my installer that he melted the lens with even a 25w kit on another customers truck. The new camaros are bad about it too
GalaxyBlackEsky
BlackedoutLT3
MD
I have 25w in mine and use them a lot and don't have any melting. Only prob with LED's it will only be for looks. The light output is not good at all.
briannorris
