Weird sound coming from behind glove compartment
fubar
Los Angeles, 818 West Valley
Lately when I am driving I hear this weird fart like sound that is coming from behind the glove box. Am not kidding sounds like a friken fart but now it seems to be doing it even more.
It even does it when I put the key in ignition. What can this be as I've never had this or even heard of this nuisance noise. Thanks
Btw its a Tahoe 2002
Sent from my cm9 ICS HP Touchpad using Tapatalk
chauncey0337
MLT, WA
I was thinking it could have something to do with one of the blend door actuators. Does all of your heat/ac functions work like they're supposed to?
fubar
fubar
Here is wat I did just now..
Turn car to Ignition on .... and right away that farting sound starts.
I turn on the heater and sound stops and the heater is running normal.
I turn off heater and within a few secs weird sound returns.
Did the same with AC and sound goes away and returns.
Any Thoughts?
chauncey0337
MLT, WA
Anything happen when you change from defrost to vents to floor heating? Fresh or recirc? Hot to cold?
chauncey0337
MLT, WA
Sounds like it might be your blend door actuator that controls floor/vent/defrost mode. Maybe the gears are worn down or stripped and that's what is making the 'farting' sound. I would inspect the actuator behind the glove box where you think the sound is coming from.
NJTaho
Central New Jersey
I'm curious to know what it is. I would agree with chauncey, it might be an actuator. Post up what you find.
fubar
fubar
isn't the actuator under the driver side above the gas pedals?
ICS HP Touchpad using Tapatalk HD
chauncey0337
MLT, WA
I believe there are at least 3 actuators. Hot/cold, mode(defrost/vent/floor), and fresh air/recirculate.
Thekenstar
